Engine oil in my Hydaulics
/ Engine oil in my Hydaulics #1
steeevo
plymouth maine
2001 kubota bx1880
HELLO<, I have a 2003 kubota 1800 bx, deisel, I did a bonehead thing today, I put a qt of engine oil in my hydaulic tank. Will it be o.k if I just change the hydraulic fluid and filter, I did run it for 2-3 minutes after I added the engine oil,, (stupid).. I was told that motor oil won't hurt it. Is this true? ANYBODY??
/ Engine oil in my Hydaulics #3
A quart is nothing in whatever many gallons the tractors holds. It won't hurt a thing.
/ Engine oil in my Hydaulics #4
I wouldn’t even change the fluid. A quart is pretty low dilution in the hydraulic system and motor oil wouldn’t hurt the hydraulics anyway.
/ Engine oil in my Hydaulics #5
I would not worry about it at all. Some machines use motor oil instead of hydraulic oil. Motor oil is a better grade of oil. Hydraulic oil is cheaper.
/ Engine oil in my Hydaulics #6
The OP’s machine is a Kubota BX1800 has both wet brakes and an HST. The recommended fluid is Kubota UDT or Super UDT. They are not a cheaper grade of oil.
/ Engine oil in my Hydaulics #7
It only costs more because Kubota oil doesn't foam. Which doesn't matter on a tractor. Now, a skid steer with a mulcher and high flow hydraulics is a different story. It needs a non foaming fluid.
/ Engine oil in my Hydaulics #8
There are many reason other than not foaming that requires high quality hydraulic fluid. HSTs and wet brakes are far more unforgiving than simple geared machines.
/ Engine oil in my Hydaulics #9
If I had a nickel for every Kubota I've worked on, I'd be rich.
/ Engine oil in my Hydaulics #10
In all my Kubota's I've never used UDT or SUDT and I've owner at least 10 and bought them all (except one) new. I do use their filters and OEM parts but the fluid is over rated and too expensive.
/ Engine oil in my Hydaulics #11
But they sure love selling that high priced oil to ya.
/ Engine oil in my Hydaulics #12
Not to me, ever and certainly not in the front axle. Front axle gets 85-140 GL4. I do get a hefty discount as I work at the dealership part time but even then, it's overpriced. Besides, both mine take almost 15 gallons on a change x 2 so that is a large amount. Been getting mine from my local lubricant supplier in 55 gallon drums, Shell Rotella hydraulic oil to be exact. Get my engine oil the same way, again Shell Rotella T6. use it in everything from the lawnmower engines, to the standby generator to the tractors to my Wife's Burb to my Focus RS. Never had issue one contrary to what Scotty Kilmer says on his YT channel.
Drop a full drum and pick up the empty and i can (but don't) return the used oil in the pick up drum. Used oil, gear oil and brake fluid goes in my waste oil furnace as it gets COLD up here in the winter and usually I don't have enough anyway. AF (not a lot) goes to the local garage up town and Safety Kleen picks that up.
The main reason why I have 2 identical Kubota's. They take take the same lubricants, filters and tires too. Only difference is one is a cab and one is an open station. same engine, same gearbox, same FEL, same buckets and same faded Kubota orange that fades to Mary Kay pink.
/ Engine oil in my Hydaulics #13
So you are using diesel engine oil in gasoline engines? I know there are different grades of oil and that there is oil to gasoline specs and a different grade to diesel specs. Can the diesel oil be used in gasoline engines? If so, why are there 2 different types of oil?
/ Engine oil in my Hydaulics #14
I’m just not as smart as some folks. I just tend to follow the recommendations of the OEM suppliers regarding lubricants and maintenance practices.
/ Engine oil in my Hydaulics #15
agree w/others, the dilution won't hurt a bit. in zero turn hydraulics, i've seen manufacturers recommend full syn mobil 1 15/50 engine oil as the fluid to use, so yes, it's sometimes used for hyd fluid. you'll be fine & just change next time w/oem filters & udt2 fluid.
/ Engine oil in my Hydaulics #16
Some diesel engine oils are also rated for gasoline engines -- they vary, a lot. You have to read the API ratings on the bottles to know what they can be used in.
Shell Rotella T6 diesel oil, for example, can be used in motorcycles, if it is JASO rated, but not all T6 formulas are JASO rated... I ran Rotella T6 full synthetic in three motorcycles, now down to just one. They all shared the engine oil with their transmissions; two were air cooled, one is water cooled; all ran flawlessly on it, as long as I stayed within the specified viscosity range, and I used JASO rated formulas.
The devil is in the detailed ratings of any jug of oil.
I put Shell Universal Hydraulic Tractor Oil into my Mahindra hydrostatic tractor transimission, and front end (4 WD, front wheels have a separate hydraulic system). Been running fine, ever since. I sourced it on Shell's site, to make sure it met Mahindra make and model spec's: they recommended two types of oil, and one was the Universal, which is readily available at my my local Fleet Farm stores; the other was a special order, and delivery fees on a 5-gallon bucket of oil was more than I wanted to pay, when I could get something locally, for cheaper, and still within spec's! My independent tractor mechanic said it was good oil to use, and I trust him. Cheers!
/ Engine oil in my Hydaulics #17
@steeevo
If I did it to my machine, I would leave it. If you were my son, I'd tell you to leave it.
If you were my client and I accidentally did it to your tractor, I would change it out.
  • Good Post
Reactions: JJT
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
2002 Pace American of Texas Trailer, VIN # 47ZA528212X020330 (A61572)
2002 Pace American...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
JOHN BLUE TANK SUB FRAME (A63291)
JOHN BLUE TANK SUB...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
