Can someone explain this circuit?
/ Can someone explain this circuit? #1
rfc143
Vermont
kubota 5240
This is from a brand new single acting hydraulic pump, probably Chinese. Documentation really sucks. It works perfectly; i.e. up button turns on pump; down button opens another valve to lower the dump body. But the circuit makes no sense to me. I can see the pump, and check valve. I believe A is a pressure relief valve, and B is the load holding valve which opens when it comes down, but what are C and D?
/ Can someone explain this circuit? #3
Since this is a dump body:
A - Pressure relief valve
B - Solenoid valve to lift/lower the bed.
C - Flow restrictor so the bed comes down in a controller manner, otherwise it would small very fast and very hard.
D - Manual ball valve to manually lower the bed in case the solenoid fails.
/ Can someone explain this circuit? #4
A is a relief valve
C and D appear to be manual valves. They may be there to manipulate the raising and lowering speed?
I'll go with you on C: I've identified a variable flow adjustor that can adjust the down speed. It's the wrong symbol for an adjustable valve, but let's not quibble.
As for D: there is no manual ball valve anywhere to be found. Perhaps some models have it; some don't? Good idea though.
/ Can someone explain this circuit? #6
The manual valve may not be a regular ball valve but a cartridge valve on the block that one would push, pull or twist somehow to let the bed come down.
/ Can someone explain this circuit? #7
Agree 100%
2017 Bobcat T770 Compact Track Loader (A63689)
2017 Bobcat T770...
2023 John Deere 8R 310 Tractor (A63111)
2023 John Deere 8R...
2008 Kubota RTV 900 4x4 Fire Rescue Diesel Utility Cart (A61572)
2008 Kubota RTV...
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
2011 Isuzu NRR Dovetail Flatbed Truck (A61573)
2011 Isuzu NRR...
2005 International 4400 Truck (A61573)
2005 International...
