Can someone explain this circuit?
/ Can someone explain this circuit? #1
rfc143
Vermont
kubota 5240
This is from a brand new single acting hydraulic pump, probably Chinese. Documentation really sucks. It works perfectly; i.e. up button turns on pump; down button opens another valve to lower the dump body. But the circuit makes no sense to me. I can see the pump, and check valve. I believe A is a pressure relief valve, and B is the load holding valve which opens when it comes down, but what are C and D?
/ Can someone explain this circuit? #3
Since this is a dump body:
A - Pressure relief valve
B - Solenoid valve to lift/lower the bed.
C - Flow restrictor so the bed comes down in a controller manner, otherwise it would small very fast and very hard.
D - Manual ball valve to manually lower the bed in case the solenoid fails.
/ Can someone explain this circuit? #4
A is a relief valve
C and D appear to be manual valves. They may be there to manipulate the raising and lowering speed?
I'll go with you on C: I've identified a variable flow adjustor that can adjust the down speed. It's the wrong symbol for an adjustable valve, but let's not quibble.
As for D: there is no manual ball valve anywhere to be found. Perhaps some models have it; some don't? Good idea though.
/ Can someone explain this circuit? #6
The manual valve may not be a regular ball valve but a cartridge valve on the block that one would push, pull or twist somehow to let the bed come down.
/ Can someone explain this circuit? #7
Agree 100%
2022 EZ-GO ELITE...
2017 Ram 5500 Bucket Truck (A63689)
2017 Ram 5500...
Root Rake Loader Attachment (A59228)
Root Rake Loader...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2001 International 4000 DT 466E (A60462)
2001 International...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
