What spray lube do you like?
   / What spray lube do you like? #31
Liquid Wrench (1) and Acetone/ATF (2), were the top two winners on the Project Farm test of penetrating lubricants.
   / What spray lube do you like? #32
I have a squeeze bottle of paint thinner mixed 1/4 with acetone. I used it while wearing gloves as a cleaner before i paint things. I'd say this is the chemical I use the most but its not penetrate to loosen frozen things.
   / What spray lube do you like? #33
Here, if I can drip on it, it gets Liquid Wrench, out of the old metal can with the plastic spout. Everyone has one. Heck, your grandfather used this stuff.
If it needs to be sprayed, it gets PB Blaster. Not sure it's the best stuff on earth, but I've been using it for 30 years, and old habits die hard.
WD40 is used for spraying on the fertilizer spreader and my tractor's 3-point ball joints after wash-down, which happens after using the fertilizer spreader. Many of the fertilizers I use are corrosive, and a quick wash-down, dry, and spray with WD40 has always done a good job of keeping rust at bay without making a gooey mess of things.
   / What spray lube do you like? #34
The Project Farm guy did a video on this for YouTube. The results were pretty interesting as I recall, but I don't remember which product was the winner.
I remember that also. I can’t remember the winner but I’m pretty sure the WD40 did well. It got a bad rap but I’m not sure why.
   / What spray lube do you like? #35
Any of you ever hear of a product called Mouse Milk? ( Real name of product) It is as effective or better than acetone and ATF and was developed for aeronautic industry. It is the best penetrating oil I have ever used on rusted bolts and nuts. It is expensive but you can buy it online. Rusted rotary cutter blade bolts? Put a few drops on the nut and let it sit for 24 hours. A friend recommended it and I thought he was joking. He was not. W Jones
   / What spray lube do you like? #36
Never heard of it. But that aside, I'm going to be at least a little alarmed if you tell me any aviation mechanic has much experience with rusted bolts!
   / What spray lube do you like? #37
I just tried this the other day. My son-in-law was a heavy diesel mechanic and now a mill-right and he swore by this and got me a can to try.
I can't give any scientific details as it's the first time I tried it, but it did get the rear wheels off my Allis Chalmers that I have never had off or used the power-adjust rims.
   / What spray lube do you like? #38
Good comment about the aviation rusting. My friend actually used the term "cold weld" to describe bonding of the metals that occurred. All I can say is I have had good luck with the product. W Jones
2021 Ford F-150XL (A57148)
2021 Ford F-150XL...
Terms & Conditions of (Buying through EquipmentDealz Auction) Final (A59213)
Terms & Conditions...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58017)
2015 FREIGHTLINER...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A55745)
2013 ORTEQ ENERGY...
