Land Pride FDR 1660 finish mower with quick hitch
   / Land Pride FDR 1660 finish mower with quick hitch #1
D
Deleted member 367166
Guest
Anybody use a Land Pride FDR 1660 finish mower with quick hitch? Looking at the manual, apparently you can't float the front end if you use it with a quick hitch. Which pretty much negates the use of a finish mower. I might as well use my bush hog!
   / Land Pride FDR 1660 finish mower with quick hitch #3
The quick hitch arms are fixed just as the lift arms. I don't see where the quick hitch makes any difference
   / Land Pride FDR 1660 finish mower with quick hitch #4
As with all Landpride (Great Plains) implements, it will have a sticker on it next to the attachment point stating quick hitch compatible.
   / Land Pride FDR 1660 finish mower with quick hitch #5
i have a kubota l3301 with a speeco cat 1 quick hitch and a fdr 1660. I also have a couple of different adapters that go into variious implements. with the floating adapter it works fine. the adapter comes somethimes with the various quick hitches or you can buy seperately at Agri supply or tractor supply. I use quick hitch on everything but post hole digger.
2019 CHEVY 5500 CAB CHASSIS (A50505)
2019 CHEVY 5500...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52128)
2019 New Holland...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-150...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2016 Volvo A25G 20CuYd Articulated Dump Truck (A49346)
2016 Volvo A25G...
