I have a water leak to or at my yard hydrant
   / I have a water leak to or at my yard hydrant #1
tomplum
Elite Member
PNW
XJ2025H
I suspected a leak and confirmed that it does....somewhere. It is plumbed w/ ~200' PVC and put the whole works in ~ 7 years ago and mostly runs the edge of the driveway. There is no outward signs of leakage. Do hydrants themselves somehow leak or is it more likely a plumbing problem?
   / I have a water leak to or at my yard hydrant #2
I always thought, rigid PVC was not permitted under code for inground
   / I have a water leak to or at my yard hydrant #3
I've replaced ours at least 3 times already and candidly, I'm sick of it.
   / I have a water leak to or at my yard hydrant #4
I had to replace mine. They don't put much galvanized coating on the pipe end where the seal is located in the ground. So it rusts and no longer seals. Tried a rebuild kit. Total waste of time. Replaced with another equally as sorry entirely new hydrant.
   / I have a water leak to or at my yard hydrant #5
Yes, hydrants leak, often from the washer at the bottom. Have you checked?
All the best, Peter
   / I have a water leak to or at my yard hydrant #6
Lots of youtubes showing how to test and replace hydrants parts.
   / I have a water leak to or at my yard hydrant #8
My brother got a government subsidy to run rigid white PVC in ground to his pastures. This causes me to think it met code for that purpose.
   / I have a water leak to or at my yard hydrant #9
Locally no agency inspects residential water lines. Even if they did a big percentage of the municipal water supply lines are pvc.
   / I have a water leak to or at my yard hydrant #10
Poly well pipe seems to be more forgiving of earth shifting around. One tip when replacing the hydrant, put a 1/4 street el and short nipple in the drain outlet, keeps debris from scoring the valve and creating a leak down the road.
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
Excavator Bucket (A50860)
Excavator Bucket...
Utility Trailer (A50860)
Utility Trailer...
2014 Forest River Crusader 295RST 32ft. 5th Wheel T/A Travel Trailer (A48082)
2014 Forest River...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
