Support-stand for two wheel -tractors: Available ? ? ?
/ Support-stand for two wheel -tractors: Available ? ? ? #1
bamsefar1
Agro 750 ps
I would like to find a support-stand for my tractor. Anybody who have seen something like this for sale ? ? ?
See picture of this kind of stands on other models as illustration.
/ Support-stand for two wheel -tractors: Available ? ? ? #2
What would the purpose be for, and what kind of tractor do you have?
I searched Agro 750 ps but did not come up with anything.
Purpose is to avoid parking the tractor in tilted position when no attachments balance/ support the tractor.
Why I care ? I just do ;-)
"Agro 750 ps" is in most specs similar to BCS 740. Made at same factory (in China...) with a few other specs.
The Agro-variant got a 13 HP Lifan engine instead of a 11,7 HP Honda-engine. The Agro 750 PS got disk-brakes while the BCS-version, I believe got drum-brakes.
Have a look at these video`s:
/ Support-stand for two wheel -tractors: Available ? ? ? #4
That stand is essential in these tractors, in my opinion. I have a small walk behind tiller that would be a pain to start without the stand in front.
It's not a very hard fabrication project to do, if you have a little bit of skill and the tooling of course. Or maybe find a shop that could do it.
/ Support-stand for two wheel -tractors: Available ? ? ? #5
Yeah, I was also going to suggest fabricating one. I am inspired to make one for my 853 now. Is the pto hookup the same on the Agro as the BCS?
Yupp. Identical.
/ Support-stand for two wheel -tractors: Available ? ? ? #8
It is like what a kick stand is to a bicycle.
/ Support-stand for two wheel -tractors: Available ? ? ? #9
Cool tractor! Where do you find such a beast? The videos sound German(maybe?). Just curious. A Googler search doesn't turn up much information.
/ Support-stand for two wheel -tractors: Available ? ? ? #10
Don Newton, of Newton’s BCS in Fairlee VT, makes a simple stand that bolts onto the engine side of the tractor. It seems to fit better on the 853 than my 749 but still works well enough. It is very basic but serviceable, with a rod that slides up and down and secures at the desired height.
I had problems with it slipping so ground grooves into the rod that solved the problem handily.
You can find Don’s contact number attached to the business on Google maps. I think I paid around $50.
Don seems to have been selling BCS for about 4 decades (!?!) and is extremely helpful.
/ Support-stand for two wheel -tractors: Available ? ? ? #11
Here's a transport wheel I made for my 739 that is a lot nicer than just a stand because you can drive the tractor with it in the down position. It pivots up for when you don't need it. Had to remove the plastic BCS cover. Used half pieces of pipe to mate up to the BCS frame tubing. Clamped everything together and tack welded it on the machine. It was a bit of a project but would not be without it.
/ Support-stand for two wheel -tractors: Available ? ? ? #12
Wow, that’s nice.
/ Support-stand for two wheel -tractors: Available ? ? ? #13
My Gravelys have the stand built in,,
it is right behind the tire, a simple "L" shaped rod, with a hand tightened set screw,,
It would be incredibly easy to copy,,
/ Support-stand for two wheel -tractors: Available ? ? ? #14
Hi bamsefar1 ;)
I have had a BCS 740 for more than 12 years now, and I was very surprised to see a 2-wheel tractor that looked almost like mine, but wasn’t.
It is a known fact I think, that many products that are sold around the world are produced - or partly produced - in China, although they are sold as being produced somewhere else. Do you know for a fact that the BCS 740 is made in China?
Looking at the domain names on the videos that you have linked, I suppose that you are living in Norway?
I like the disc-brakes! How cool is that with disc-brakes on a 2-wheel tractor 💪
The tractor sold in Norway by wee.no could be this one: https://en.hongyuetools.com/guoyuanjixie/112.html
A quick look at the tractor and the implements available, shows similarities to products that we are familiar to from other brands, therefore I think it will be difficult to find this tractor for sale in the US, Canada and the EU.
Best regards
Jens
/ Support-stand for two wheel -tractors: Available ? ? ? #15
I built this one, very similar to NibbanaFarm. A simple plate bolted to the bumper, the rest just pipe and threaded rod, what ever I had laying around. The wheelbarrow was also homebuilt years ago, one of the most useful implements for year round use. The oil is not from the BCS, changed a filter on a Kubota and made a mess.
/ Support-stand for two wheel -tractors: Available ? ? ? #16
You guys are much more skilled and/or handy than I am! Both of these supports look great.
