Rear axle seal
/ Rear axle seal #1
DrRon
Jones, OK
JD 3020, JD 830, JD - A
My 1948 JD Model A has an oil leak at the left rear axle. It is apparently due to a bad seal. I found out the those seals are obsolete from the local JD dealership. The service man said that I would have to contact NAPA to see if they could make one. Do any of you have any idea of how this issue can be resolved?
/ Rear axle seal #2
JD collector association or restoration club might know a substitute
/ Rear axle seal #3
Measure the shaft diameter, and measure the housing bore. I am about 100% certain there is a common seal number that exists that fits those dimensions.
/ Rear axle seal #5
I get my old two cylinder JD parts from SteinerTractor.com. Order online and it is here in a few days.
They have both the original and upgraded axle seals. So far everything I get from them is top quality.
In fact, that's where my JD dealer gets a lot of his parts too.
rScotty
/ Rear axle seal #6
I've replace a lot of seals. Never bought one at a dealer.
/ Rear axle seal #7
Well, at least you did get one issue resolved, that being the knowledge level of the service man at the local JD dealership. Advising someone to ask NAPA make a seal is beyond strange; it's pure sci fi.
rScotty
2015 Caterpillar CB24B (A60462)
2015 Caterpillar...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2012 PETERBILT 386 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2012 PETERBILT 386...
Mini Ex Rake Attachment (A60463)
Mini Ex Rake...
2012 International Prostar (A61307)
2012 International...
CFG Industry 680 QA Hydraulic Breaker (A60463)
CFG Industry 680...
