What could have caused this ???
/ What could have caused this ??? #21
I don't buy the microburst story for a second. That's not wind damage, that's impact damage. Perhaps a chunk of "blue ice" ball falling from an airplane....aka toilet flush. Could be anything falling from the sky, piece of space debris, etc. If the thunder was several seconds before the impact, possibly a meteor broken up and a piece crashed into the house. This is a low angle impact, certainly not wind damage. Microbursts are not that micro.
/ What could have caused this ??? #22
I read years ago where a person (forest ranger I think) was hit by lightning on a nice sunny clear blue sky day. It was attributed to some thunder clouds over the mountain out of sight of the person. However I do like the idea of a UFO until proven otherwise. Makes sense until it doesn't.
/ What could have caused this ??? #24
Some type of object impacted that roof. Pictures show that in sufficient detail.
  • Good Post
Reactions: SPM
/ What could have caused this ??? #25
It's not unheard of for ice to fall off an airliner and damage property. Ice would also melt leaving no evidence. Is the property in a flight path?
/ What could have caused this ??? #26
I don't buy microburst in a clear blue sky. Other items would have been affected, like lawn furniture, and really anything that isn't nailed down. I've seen microbursts, and they can flatten forests and throw large objects around.
UFO's? Just because it is an unknown cause, doesn't mean that it should be blamed on another unknown. Why not say witches?
How hot was it? Could they have buckled from expansion from the heat and all let loose at once? Weather history for the past several days says temps of 108, so the roof temp in the sun would have been much more. If a couple rows were installed more tightly, then expansion would have had no where to go but up, and it makes sense that it was a sudden event, and causing a loud noise too.
/ What could have caused this ??? #28
Weird how none are cracked…
All,
There was no damage to the underpinning plywood, or even the vapor barrier. Also, there were a lot of leaves in his pool and he doesn’t have trees. The cover to his grill (under back porch) was also off and on the ground,
Believe me, I’m leery of the microburst theme too, but both the roofer and insurance agent agree on microburst.
One other possibility (and it fits into the wind made theory), is a heat driven dust devil. If it made contact at the worst part and moved westward ( to the rt) maybe that could have driven this. Dry lightening? There were no thunder storms anywhere w in 50-100 miles. Lightening also leaves charred marks..no such thing. And if it was an object of some sort, wouldn’t the impact hsce broken some of the tiles? None of them were broken.
/ What could have caused this ??? #31
...a 90-100mph microburst. ....mother nature is bad axx ...
A couple years ago we had a similar microburst remove the 12' X 40' lean-to from the side of our barn, fly that structure over the 60' length of the barn, fly another 100' towards our house and land next to our garage... there was no damage to the barn roof, not even a scratch... fortunately, the only damage to the garage was from a concrete footer which went through the window and landed on my workbench...
This is where the lean-to came from, the ledger board stayed attached to the barn...(that's a wall laying in this picture) the house/garage is visible in the distance...
This is where the lean-to landed, the window behind the destroyed awning is where the footer went through...
we weren't home at the time, but it had to be an impressive sight to see...
Bad ass, indeed!!!
/ What could have caused this ??? #32
Hello to all,
My brother lives in Chandler AZ, and he contacted me yesterday (Sunday) about 5pm CST. Said he heard what sounded like lightening, but it was clear blue sky except for high cirrus clouds. His back nbor stated they heard it too, and noticed the backside of his roof had damage.
Here are 3 diff pics. It looks like most of the damage is on the left (east) side snd as it goes westward, the damage lessens. He’s having a roof guy come out later today.
Pls let me know what you think? Thank you.
I grew up in Arizona and there was what was called HEAT lightning. Other than that, could a large drone have impacted the house?
/ What could have caused this ??? #33
Had similar happen to me one night on a javelina hunt near Kingman, AZ. Microburst picked up my large "EZ-up" awning that was staked to the ground in camp, and carried it over my tent and set it down again directly in a prickly pear cactus patch a couple hundred yards away. The frame on the EZ-up was badly bent, but the funny thing was everything that was sitting on my large camp table under the awning was perfectly fine. Even the plates and cups were sitting where they were placed. Didn't even break my (glass) coffee pot or knock over my camp stove.
/ What could have caused this ??? #34
Somebody at Sky Harbor might have some 'splan'n to do.
Is his house in line with a highway? I could see a wheel bouncing up off a curb and doing that. Which means the wheel is some where down range from the line on the roof. . :)
Interesting theory. One my coworkers had a dual wheel/drum/axle part company with the milk truck, hit the car parked in his front yard and get launched into his attic. At 3am. They slept right through and never heard a thing until the driver was out front ringing his doorbell.
/ What could have caused this ??? #35
A microburst is exceedingly unlikely if the sky conditions were really as described. Their generation requires CU (thunderstorm) clouds. I assume the "sounded like lightning" means a thunder sound. I would wonder if a tiny meteorite might have impacted the roof. they can generate a supersonic shock wave that sounds like thunder and cause a lot of damage for their tiny size. Just guessin'.
/ What could have caused this ??? #36
Microbursts can be wet or dry, but they’re only associated with thunderstorms.
If the damage was due to impact from a falling object there would be more broken tiles and the damage wouldn’t be spread out over the length of the roof.
I think that the most likely explanation is a dust devil. The atmospheric conditions were right and they can be just tens of feet in diameter, causing very localized damage.
/ What could have caused this ??? #37
Seems like fragmented small meteorite is most plausible. Go with anything that the insurance will pay for.
/ What could have caused this ??? #38
It's obviously the work of Tr--ps little friend Rocket Man.
He's been firing missiles willy nilly lately.
Maybe one got away on him.
/ What could have caused this ??? #39
I'm not buying the micro burst hypothesis at all. The tiles would have been scattered by the whirl wind. A few tiles are cracked. Something strafed this roof in a line. And I think it landed on the left, and ran off to the right. So somewhere to the right of the property you will find the object.
/ What could have caused this ??? #40
Had a microburst about two years ago. Saw it. 30 feet wide by hundreds long. Took out some trees like a new path in the woods...section of fence...half a run in shed roof 20 feet wide...15 feet off the barn roof...another section of fence and then some more trees as it left the property. Flipping unreal.
The run in shed roof came off in one piece and laid next to the shed. The barn roof was not as clean...mangled actually. The trees some topped off others pushed over. Nice straight line.
Mother Nature is amazing.
Topsoil Trommel (A57453)
Topsoil Trommel...
LILLISTON 2R ROLLING CULTIVATOR (A63291)
LILLISTON 2R...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
JOHN DEERE 11 SHANK CHISEL PLOW (A63291)
JOHN DEERE 11...
John Deere 4300 32HP Front Loader Utility Tractor (A61572)
John Deere 4300...
