td8g dresser steering pump?
/ td8g dresser steering pump?
Thanks, I wasn't sure and no doubt the oil will have to be caught in a container , maybe cut the side out of an oil bottle but not much room there. Lucky because i could have damaged something just screwing it.
You wouldn't know the cartridge number would you?
If not i have to take it off and bring it back in to town to match it .
Does the strainer have an o ring on the suction tube ? I didn't look up there , just stuck small rag into hole with finger.
I pulled it off and have it and the filter cover which i need a ring for, but after coming home i thought it must have one smaller ring on the tube to seal the top of the strainer into the tube.
I got a picture of the suction filter and it does have an oring on top.
I rang Komatsu they can order them but it will take a while and cost a heap .
Does it sound ok to just match them from a bearing services ?
Or does someone know the sizes ?
/ td8g dresser steering pump? #23
You’re right - not much room. Taking battery out helps. I don’t know size of o-ring. Don’t see why a match would not work for the same pressure and oil use ??
gg
/ td8g dresser steering pump? #24
Feeling a bit better so i at least wanted to pull strainer. It confirmed to me anyway i'll have to do the pads. lots of junk and fine steel wires, bits of the pads i think, and probably why the pressure dropped, I could not get the filter off. Looks to me like a screw in outer with drop in filter and the bolt on bottom is just a drain . Is this right ? . I went into town and bought a tool to unscrew it.
when you get to your brake job you may want to find Salam Sayhood on youtube. Go to a list of his videos - he has a ton of them - go back three years in the list and find TD7C bulldozer brake & clutch job. It is excellent on reassembly. Also find Repair Bulldozer Brake and Clutch where he does the initial internal inspection and removes all the parts.
gg
Thanks i found the one re fitting everything but have nit seen the inspection one. You don't know the thickness of the pads do you?
There looks to be heaps of adjustment , might go for 10mm from looking at pictures if i can't get a size.
/ td8g dresser steering pump? #26
I Am not near my shop manuals today. Tomorrow I will have a look and let you know what I find about the pads.
gg
/ td8g dresser steering pump? #27
My service and parts manuals do not say anything about the pad thickness. Only disassembly and assembly instructions. Komatsu still lists the parts with a link to 777parts.org/amazon for an aftermarket replacement part, but no specs there either just pictures. Maybe you can find some specs ???
Komatsu/Dresser Brake shoe tube P/N 1244 967 H911
Back-up shoe P/N 1244 903 H911
gg
Fleetguard HF- 6151 is the hydraulic oil filter number. On my machine , not sure about other models . HD8g , in australia if that makes any difference.
/ td8g dresser steering pump? #30
Yes, Fleet Guard HF6151 or Baldwin PT376
gg
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
2014 Club Car Golf Cart (A62613)
2014 Club Car Golf...
1995 VOLVO A25C WATER TRUCK (A65053)
1995 VOLVO A25C...
2018 KOMATSU WA270-8 WHEEL LOADER (A65053)
2018 KOMATSU...
2022 EZ-GO ELITE...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
