My wires are too damn short.
   / My wires are too damn short. #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
I am replacing an old floodlight setup on the side of my house with a bigger LED light. The problem is after removing the old fixture, I realized the wires coming from the house are not long enough to reach into the new fixture. I was thinking of putting a junction box where the old light was and running wires from there to the new light.
Any better ideas out there?
Thanks
Dave
   / My wires are too damn short. #2
How does the new fixture mount? Can you mount it to an exterior utility box? Then you can just add some short pigtails.
   / My wires are too damn short. #6
If you can't make them work because of their length just splice them with some end to end connectors or wire nuts.
   / My wires are too damn short. #7
If your going to use wire nut wrap them good with electric tape...3M.
   / My wires are too damn short. #8
Been accused of something else being too short but not lately. Once you reach 70, being too short is not important. So long as it clears your zipper, all is good.
   / My wires are too damn short. #9
But if you shake it more than twice, you're playin' with it...
   / My wires are too damn short. #10
Me...I'd just use same gauge solid copper wire, scrape those clean, make a western union splice, flux and solder. Same black, white, bare copper & double heat shrink white & black.
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
Bear Statue (A53316)
Ford 7600 (A53314)
Ford 7600 (A53314)
2010 John Deere 7130 (A53314)
2010 John Deere...
(2) GAS HEATERS (A54757)
(2) GAS HEATERS...
