I'm cutting 18-19 acres. I cut it in sections until I get tired and then stop rather than operate the tractor when I'm tired. So it takes me about three days or so to cut it all. I usually cut it all at least twice a year.
Some of it is pretty bumpy. There are some hilly sections where tractor stability is very important. There are some hill sections I don't mow at all.
Part of my problem is figuring out what I really want. On the one hand, I'd like a cab with AC because of our summer humidity levels. Also, I've been swarmed by stinging wasps three different times.
On the other hand, being able to pull a 7-8' cutter would reduce my cutting time, but I think the 394c HST would be at its limit with a 6' cutter.
The least expensive option would be to repair my 3525 and keep using it. That would also avoid the hassle of trying to sell it or trade it. Other than the brakes not holding because of a transmission oil leak, the 3525 starts and runs fine. Although it only has 771 hours on it, it could be pushing 20 years of age. I like the simplicity of the 3525. Just push the clutch, select the gear range and engage the PTO mechanical lever.
Some TYM things puzzle me like why engaging the PTO is apparently a three step process, two of which appear to involve a manual/auto selector switch followed by pushing a button on the dash. I understand the auto PTO switch is a feature for raising implements with short PTO shafts, but it seems to me that adding electrical switches to engage the PTO is asking for trouble long term.
Other than the 6' cutter, the implements I use the most include a grapple for getting broken limbs out of the fields, and a box blade for maintaining a driveway with a 12 degree slope.
