Grease shortage
/ Grease shortage #1
Hay Dude
Epic Contributor
The Last Red State in the Northeast
Challengers: MT655E, MT555D, MT535B, Massey 7495, Krone 4x4 XC baler, 2-Kubota ZD1211’s, ‘20 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 38K trailer, Deere CX-15, 2 Pottinger Hay mowers, NH wheel rake, Claas 30’ tedder
So here we go again. Polyurea grease in MY area sold out ”indefinitely”.
No John Deere Green polyurea or Lucas green polyurea grease anywhere.
Checked everywhere, box stores, hardware stores, farm stores, tractor dealers. Nothing, zip, nada.
I have 2 automatic greasers I have to keep loaded with grease or Hay Dude makes no hay.
So the question is, what type of grease mixes with polyurea grease without clogging issues?
Things are getting desperate.
/ Grease shortage #3
I only use this in my auto greasers. I was actually told by Groeneveld that if I use their grease it increased my warranty on the greasers by a couple years. It flows really good even in minus 40.
/ Grease shortage #4
mail
WE HAVE EXTENDED OUR FREE SHIPPING OFFER! This offer is now good until Thursday, July 13th at midnight EST.
Make your dollars stretch further with our FREE SHIPPING offer, going on now until Thursday, July 13th at midnight EST. This offer qualifies on most orders of $99 or more when you apply the coupon at checkout.
Free Shipping Coupon Code: SHIPONGFP​
You must enter coupon code SHIPONGFP in the coupon box at checkout to receive this offer. Not valid on previous orders, with other coupon codes, oversize items, buckets of oil or weights. AK and HI are not included in this offer.
What's that coupon code again? SHIPONGFP
Is there a qualifying order amount? Yep. $99 or more.
/ Grease shortage
John Deere green grease on national back order.
Lucas green similar.
Need 20-50 tubes
/ Grease shortage #6
the ebay listing says last one available.
/ Grease shortage #9
I don't know that answer. Polyurea is the thickener in the John Deere HD Polyurea Grease that carries the oil like a sponge carries water. And we've discussed before that Lucas Green seems to use the same chemistry as the JD Poly...so those two should be as interchangeable as greases get.
Just for some background so others can follow this grease problem :
Greases are basically oil soaked into a thickener like water into a sponge. Several substances are used as thickeners. Polyurea is a popular powder thickener because it is a reliable synthetic. Other greases use either a soap or a clay based thickener. Soaps and clays both are built around light metal molecules mostly of lithium, calcium, barium.
The oil used in the thickener is not the problem. All the oils are compatible. The problem is that when incompatible greases get together they harden and at the same time they expel their oil
This is because different thickeners are chemically reactive with each other. They don't corrode the bearing surface, but instead they can react to clump up, harden and cake. When they do, they take up space and while they do their clumping they dump their oil content. Basically if you use incompatible greases the bearing space becomes filled up with dirt and no room for oil. You can see it easy enough if you take the joint apart. You end up scraping out this dry crud. Usually the first clue you have to incompatibility is that the zerk seems to nbe jammed or stuck or shut or not accepting grease.
Hay Dude, I don't have an answer. JD SD Polyurea (and Lucas) advertise as being a new style shear stabilized poly urea - they used to be conventional but changed - and shear stable is way better than the old conventional poly....but I'd still stay away from calcium and lithium based greases anyway. Even the JD products.
Frankly I'd find the genuine JD/Lucas or skip a couple of lube cycles. Maybe rig up a zerk injector to pump in some 80/90 in critical joints until I could get some genuine. This sucks....
Some literature - some if a bit deep - is attached. The RP report is valuable because it compares different manufacturer's compatibility charts instead of comparing compatibility directly.
The other one is heavy on chemistry... read at your peril...
rScotty
  • RP2016_Wurzbach_GreaseCompatibility_Rev3.pdf
  • Poly Urea Greases white paper.pdf
/ Grease shortage #10
I looked on Amazon.ca, you don't want to buy it from Canada, not at this price for 10 tubes
/ Grease shortage
There’s places to buy grease, and there’s places gouging people for grease.
After I discovered Wal mart, John Deere and every local store is out (except I found 3 tubes at an Auto-Zone), I asked one of my kids to poke around on the internet.
O’Oreilly Auto parts had 150 tubes in a warehouse. (You know….O-O-O- O‘reilleeeeeeeeeeee Auto parts OW!)
I ordered 40 of them at about $7.50/tube. Should be here Wednesday.
Now I can go back to baling next week. Sheesh…
Still think it’s ridiculous how grease goes out of stock seemingly every summer for the last 2-3 years.
I guess I will have to make sure to buy plenty over the winter.
/ Grease shortage
/ Grease shortage #13
The automatic greasers we had in mining were bulk filled 5 gallon tubs. Is yours set up for only tubes? I'm confused.
/ Grease shortage
It’s a bit smaller than one on a mining machine. Holds about 15 tubes of grease. Krone gives you a special loader for it. You put the tube in the loader, pull plunger back and push the tube of grease into a 1” opening, then push the plunger in from the back to push the grease into the reservoir.
It’s typical for me to push 5-10 tubes into it. Has a “low grease” warning on the monitor in the cab.
/ Grease shortage #17
Ah, makes sense now. Thanks
/ Grease shortage
/ Grease shortage
everyone should copy that chart
2013 WACKER NEUSON HF 690 FLAMELESS HEATER (INOPERABLE) (A68842)
2013 WACKER NEUSON...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
Unused 2021 NM 2HD-18 18in. Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2021 NM...
2025 Grapple Rake Mini Excavator Attachment (A66734)
2025 Grapple Rake...
2016 John Deere 250G LC Hydraulic Excavator (A66734)
2016 John Deere...
FIXED FIFTH WHEEL ATTACHMENT (A67714)
FIXED FIFTH WHEEL...
