another hiccup to going solar?
   / another hiccup to going solar?
As others have said before and will again, there are microgrid systems which form a separate micro grid when the main grid is down.
Mine does this with battery and/or generator backup; the solar can continue to generate power as needed.
Now, you know otherwise.
😂 😂 If the solar is generating power as needed why do you have battery/generator backup?
   / another hiccup to going solar? #152
Yep! It never gets dark or cloudy,,,,,,right?
Thing that really scares me is the manufacturer of the controllers & systems could imbed computer chips in them that could suddenly become unavailable, or even have ways of turning them off, just like in our cars & trucks.
But don’t worry about THAT. ;)
It’s all good.
   / another hiccup to going solar? #153
Cute.
Because the vast majority 99+% of solar adopters (the 1-% being true off grid systems) consider the solar system/production as ‘part’ of their energy solution. Most of us are very aware of where the balance of our power comes from: larger wind/solar installations, NG, coal, biomass, oil, hydro. The battery/generator backup is for the failure of the grid system. Not our own solar installation. In general, residential small scale solar installations are reducing load on the grid during peak times while in production. Despite MSM/Politicos spouting opinions, only a tiny fractional percentage of people actually think wind/solar is a viable option for ALL energy production.
   / another hiccup to going solar? #154
It’s all good.
And that is different from any other power generation how? Modern power plants aren’t run like and 1850s saw mill… They are all computer controlled. All with foreign non-US components (from materials mined with “African Slave Child Labor”, I’m sure)
Who needs to worry about computer chips? 2 rifles against oil filled utility transformers has already been enough to cripple US grid in very recent history.
   / another hiccup to going solar? #155
It all boils down to spending money to save money which is nuts. That and man creates pollution doing things so doing other things will fix the original problem as people ride their private jets explaining how it's done.
   / another hiccup to going solar? #157
About once every 10 years I fly to visit family…
I must be an outlier because among friends and co workers flying several times during the year for pleasure is typical.
Thailand, Europe, New Zealand, Mexico and Central America and Philippines top the list…
Yet using 5 gallons of mix in my string trimmer/brush cutter every spring chopping weeds required for fire suppression is destroying the world…???
   / another hiccup to going solar? #158
This is only because the "informed" have set a zero emissions goal!
The goal is control!!
Yet, the "informed" don't believe in zero emissions for themselves!!!:cry:
Cute.
There is nothing cute about it.
AGAIN, without violating NEC standards, what amount of power does a grid tied system generate when the grid goes down? just under 2 kw max? Which is only useable on a completely separate circuit (ie extension cord) or to feed a Tesla Powerwall, Enphase IQ, etc…(extra 10k ++) just enough to run one refrigerator and a couple of lights.
Im happy you and others think this is a magic pill.
This is merely another (government incentive) distraction. Why isn’t geothermal HVAC more subsidized, a large percentage of your energy use is allocated for your comfort (heat, ac, domestic hw)? Wave power, where’d it go? Remember when solar water heaters were the rage? Remember when propane/NG was the countries saving grace? Auto manufacturers pushed mass transit aside, now we want more mass transit. The list goes on and history will repeat itself, again.
   / another hiccup to going solar? #160
I'm starting to think you're being obtuse on purpose. I'm going to answer this one and see.
When the grid is down the batteries run the inverter which powers the house. The panels charge the batteries when they have sun. The generator is for when the panels are not enough, like for a days-long outage in winter with overcast.
My neighbors have a setup like this. It runs their whole house. When we had a couple week+ long outages this winter, they had to run a portable generator a couple hours a day to top up the batteries because the panels weren't enough between overcast and snow (which is rare here). It's a really slick system and totally to current code. It sure beats running a generator 24 hours a day or turning it off at night and not having power.
It costs more than the usual whole house generator run off a propane tank. But our neighbors who had those both ran out of propane during the outages this winter. Propane trucks can't deliver when the road is closed, which is not infrequent here. If you're in a place with a lot of outages and can afford it, solar + batteries + small generator is the way to go with the current state of technology.
UNUSED Jack Lift 5/10 Ton (A53117)
UNUSED Jack Lift...
30007 (A53424)
30007 (A53424)
Utility Trailer (A52377)
Utility Trailer...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
202474 (A54757)
202474 (A54757)
2009 CAT 140M MOTOR GRADER (A55745)
2009 CAT 140M...
