Another B&S Engine mystery.
   / Another B&S Engine mystery. #1
SARG
Upstate New York
NH T1030- NH T1530 - 49G Brockway
I have a Husqvarna 2354GXLS tractor with a B&S engine. Yesterday I changed out the transparent in-line fuel filter. Today I used the machine for about an hour without any issues. Before I put the machine away I lifted the hood from the seat to double check that the new filter was not leaking.
I was surprised to notice that the fuel within the transparent filter looked like it was boiling ......... a multitude of "air bubbles" were entering from the tank side.
I have never noticed this before and now I wonder if there is an issue I should address.
Has anyone else noted this on their engines ?
I'm suspicious it might be heat related.
   / Another B&S Engine mystery. #2
if your not having a issue leave it alone. My mower has the gas tank above the engine. I have literally seen the gas boil on a hot hard load day, that was 8 years ago and I still haven't needed to do anything.
I just got back into the house. I can never leave anything I don't understand alone.
I replaced the spring action clamps with some worm drive to eliminate possible air intake and also wrapped the fuel line were it is near the engine components with a length of split ¾" pipe insulation.
Time will tell.
   / Another B&S Engine mystery. #4
Was the engine running when you looked at the filter as saw the bubbles?
Where is fuel tank in relation to filter and fuel pump?
Reason for asking is that some of the lower cost filters I have seen had a pretty large seam from mold process that could allow air to leak past especially if pump is lifting or drawing fuel through the filter. Your worm clamp could solve that problem.
Machine was running & the fuel tank is in the rear over the tires.
Lots of mowing required tomorrow so that should tell if I've made any change.
   / Another B&S Engine mystery. #6
I had a Volvo Penta Boat engine do that but it was caused by aged fuel line,
The engine used a mechanical diaphragm style pump but had to draw through the tank one way valve which was in the front of the boat.
Boat ran great for a few years but started seeing bubbles in the clear test filter I put on when the boat started needing extended cranking to start.
I started looking very close at the 16 foot fuel line which was pushed up against the carpet under the gunnels. and noticed "dark" spots every few inches in the carpet.
At that point I did a vacuum test on the line itself and sure enough it would not hold a vacuum.
Installed new marine fuel line and the bubbles disappeared as did the extended engine cranking then reinstalled a metal cased filter.
Just another way the fuel can appear to boil- but is not a heat related boiling of the fuel.
   / Another B&S Engine mystery. #7
I has similar "bubbles" while engine was running (B&S powered mower) .... Engine was also miserably hard to start.... Found bad fuel line between tank and filter... It had microscopic holes that would allow air into system but were not large enough to show as a fuel leak.... It was all about the size of the molecules of fuel vs air....
   / Another B&S Engine mystery. #8
You should really replace those barbless filters. Doom, despair and agony they will bring. Trim the line to get a good seal.
   / Another B&S Engine mystery. #9
Chances are a vacuum is lowering pressure and gas is evaporating.
Perhaps ....... But I've been using them on five machines without issue for a couple decades until this mystery.
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
4 1/2 150G DRILL STEM 358 JOINTS (A50854)
4 1/2 150G DRILL...
2013 UTILITY VS2DX 53FT DRY VAN TRAILER (A51222)
2013 UTILITY VS2DX...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
