Where can I the Mahindra CRD Full Diagnostic Manual with Check Engine Codes
   / Where can I the Mahindra CRD Full Diagnostic Manual with Check Engine Codes #1
Clayak
Member
Emax 22s
Mahindra CRD Full Diagnostic Manual with Check Engine Codes I have read there is a CRD for diagnosis of Mahindra problems but I cannot find how to order it.​
With no replies over the last 6-7 weeks, I guess there is no manual of CRD codes for the Mahinda. LISTEN UP MAHINDRA, MAYBE YOU NEED TO GET YOUR BUTTS IN GEAR AND DO SOMETHING.
   / Where can I the Mahindra CRD Full Diagnostic Manual with Check Engine Codes #3
Zipped for you
  • ezyzip.zip
Thanks 'hillbilly' for the reply and attachment. One question ... are the codes applicable to the Mahindra Emax 22 series? I see on page 1, the tractor pictured is the Arjun Novo.
   / Where can I the Mahindra CRD Full Diagnostic Manual with Check Engine Codes #5
Im sure the codes are pretty much the same along all the Mahindra line up. Just like Ford or GM have pretty much Generic codes for their vehicles. A Ford code p1100 means mas air flow sensor problems on a F150 and a mustang. It would get pretty confusing if it meant mass air flow on the F150 and knock sensor on the mustang.
Will take your word for it. Thanks much.
   / Where can I the Mahindra CRD Full Diagnostic Manual with Check Engine Codes #7
you are forgetting that that tractor is made by a different manufacturer and the tractor CAN bus is not a standard like the mandated car standard where a code by law has to match between all cars.
that list is a good start but i would not put to much faith in it to be accurate.
but it is better than nothing in my opinion.
   / Where can I the Mahindra CRD Full Diagnostic Manual with Check Engine Codes #8
I'm not a smart man. I just do what I do. I dont know anything about can busses or much about anything, I'm definitely no mechanic and Im wrong way more than I am right.
   / Where can I the Mahindra CRD Full Diagnostic Manual with Check Engine Codes #9
i'm right there with you lol
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2006 Kenworth T600 Semi (A50514)
2006 Kenworth T600...
400 bu Gravity Wagon (A50514)
400 bu Gravity...
2025 DOWN 2 EARTH GOOSENECK TRAILER (A51243)
2025 DOWN 2 EARTH...
UNUSED CFG INDUSTRIAL PD680-PZ POST POUNDER (A51244)
UNUSED CFG...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
