Mounting a JD 48 Backhoe on a JD4600
/ Mounting a JD 48 Backhoe on a JD4600 #1
pctwst
Member
JD 4600
Hi All,
I just picked up a JD 4600 at auction and I am excited. A friend has a JD 48 backhoe that I can buy cheaply. It is coming off a JD 4310. Does the 4310 and the 4600 use the same side mount brackets? If not, does anyone have a part number for the 4600 mounting brackets? I have been trying to look at the JD parts diagrams but can't figure it out. Also I would like to use new bolts to mount the brackets. I have read that people have bought the bolts from JD. Are they special? Or would any grade 8 bolt work? The 4600 has a set of rear remotes. Can that be used for the 48 or do I have to buy the Power beyond kit?
Last question: I am also looking for a JD 460 loader for the 4600. Problem is they aren't made anymore and I can't find a used one. Are there any other loader recommendations that will mount easily to a 4600?
Thank you!
/ Mounting a JD 48 Backhoe on a JD4600 #2
I purchased a 48BH for my JD 4500. It had the subframe with it that connects under loader brackets of a JD 5205. I could not located the correct mounting brackets either.
I decided to use the subframe because it was a better way to mount. A Woods 9000 has a similar subframe. I purchased the mounting brackets for the Woods subframe then I had to modify the JD subframe some.
The rear mount on the JD is a smaller diameter rod than the Woods. Instead of replacing the rod I found some DOM tubing with correct id/od and cut it lengthwise wrapped it over existing rod and welded it back together.
It came with the front mount for the JD 5205 but I had to cut part of it off to bolt it to the Woods mounts.
Now the frame was to short. The JD subframe is c channel that is boxed almost end. I extended the subframe using same size c channel. I extended the boxing on the inside and used oversized fish plated on the outside.
I can take it on or off in 15 minutes. Tractor is very stable/solid feeling while using backhoe. The mount does take up alot of ground clearance but it has not been a problem yet. I will get some pics today.
/ Mounting a JD 48 Backhoe on a JD4600 #3
Pic of the Woods and JD frames.
Wow, sounds great! Thanks for the reply! That is a bit more than I can do myself. I am a terrible welder. Lol
/ Mounting a JD 48 Backhoe on a JD4600 #5
Hi All,
Thank you!
There was a guy last week that had a 48 he was going to buy ( was on fb john deere compact tractors ) that had the brackets for a 4600. he needs the brackets for a 4300. maybe you guys could switch? I'll see if I can find the link.
here is the link . took me a bit to find it.
/ Mounting a JD 48 Backhoe on a JD4600 #6
Sorry for the delay on pics. I had/ have a kidney stone. I took the backhoe off today and got some pics
/ Mounting a JD 48 Backhoe on a JD4600 #7
more pics
Thank you!
Thank you!
(8) 16' TARTER CATTLE PANNELS (A63291)
(8) 16' TARTER...
Claas Lexion 700 Series Folding Grain Bin Panels (A63117)
Claas Lexion 700...
RoGator RG1300C (A63688)
RoGator RG1300C...
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
John Deere 4955 (A64119)
John Deere 4955...
