Mounting a JD 48 Backhoe on a JD4600
/ Mounting a JD 48 Backhoe on a JD4600 #1
pctwst
Member
JD 4600
Hi All,
I just picked up a JD 4600 at auction and I am excited. A friend has a JD 48 backhoe that I can buy cheaply. It is coming off a JD 4310. Does the 4310 and the 4600 use the same side mount brackets? If not, does anyone have a part number for the 4600 mounting brackets? I have been trying to look at the JD parts diagrams but can't figure it out. Also I would like to use new bolts to mount the brackets. I have read that people have bought the bolts from JD. Are they special? Or would any grade 8 bolt work? The 4600 has a set of rear remotes. Can that be used for the 48 or do I have to buy the Power beyond kit?
Last question: I am also looking for a JD 460 loader for the 4600. Problem is they aren't made anymore and I can't find a used one. Are there any other loader recommendations that will mount easily to a 4600?
Thank you!
/ Mounting a JD 48 Backhoe on a JD4600 #2
I purchased a 48BH for my JD 4500. It had the subframe with it that connects under loader brackets of a JD 5205. I could not located the correct mounting brackets either.
I decided to use the subframe because it was a better way to mount. A Woods 9000 has a similar subframe. I purchased the mounting brackets for the Woods subframe then I had to modify the JD subframe some.
The rear mount on the JD is a smaller diameter rod than the Woods. Instead of replacing the rod I found some DOM tubing with correct id/od and cut it lengthwise wrapped it over existing rod and welded it back together.
It came with the front mount for the JD 5205 but I had to cut part of it off to bolt it to the Woods mounts.
Now the frame was to short. The JD subframe is c channel that is boxed almost end. I extended the subframe using same size c channel. I extended the boxing on the inside and used oversized fish plated on the outside.
I can take it on or off in 15 minutes. Tractor is very stable/solid feeling while using backhoe. The mount does take up alot of ground clearance but it has not been a problem yet. I will get some pics today.
/ Mounting a JD 48 Backhoe on a JD4600 #3
Pic of the Woods and JD frames.
Wow, sounds great! Thanks for the reply! That is a bit more than I can do myself. I am a terrible welder. Lol
/ Mounting a JD 48 Backhoe on a JD4600 #5
Hi All,
Thank you!
There was a guy last week that had a 48 he was going to buy ( was on fb john deere compact tractors ) that had the brackets for a 4600. he needs the brackets for a 4300. maybe you guys could switch? I'll see if I can find the link.
here is the link . took me a bit to find it.
/ Mounting a JD 48 Backhoe on a JD4600 #6
Sorry for the delay on pics. I had/ have a kidney stone. I took the backhoe off today and got some pics
/ Mounting a JD 48 Backhoe on a JD4600 #7
more pics
Thank you!
Thank you!
2011 Energy Absorption Systems TMA9000 19ft Attenuator Trailer (A61573)
2011 Energy...
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
2006 Ford F-150 Ext. Cab Pickup Truck (A61573)
2006 Ford F-150...
2022 EZ-GO ELITE...
Screen USA CF35D2 Tri Axle Towable Trommel Screener (A61572)
Screen USA CF35D2...
2016 FORD EXPLORER SUV (A64280)
2016 FORD EXPLORER...
