Driving tractor with the front end loader bucket elevated .
/ Driving tractor with the front end loader bucket elevated . #1
RidgeTopWVA
Gold Member
John Deere 4400
I have noticed some people driving there tractors with the front end loader bucket about 3' to 4'ft
off of the ground while mowing or brush hogging and I am wondering why some people do so . I always keep the bucket low to the ground .
/ Driving tractor with the front end loader bucket elevated . #2
While brush hogging I favor removing the bucket for visibility and keeping the FEL frame work below my sightline over the front of the hood.
I have mowed with the FEL removed but the front traction suffers.
/ Driving tractor with the front end loader bucket elevated . #3
Maybe mowing real tall stuff and don't want the bucket pushing it down. Perhaps better sightline - looking UNDER the bucket. OR they simply don't realize the increased dangers.
/ Driving tractor with the front end loader bucket elevated . #4
If there is nothing in the bucket the danger of rolling is not much more than with no bucket. I usually have mine off (both of my Kubby's have SSQA buckets). but sometimes I'll keep the bucket on and raised above the stuff I'm mowing.
/ Driving tractor with the front end loader bucket elevated . #5
Keeping the bucket low when shredding tends to fold over whatever you are mowing and loosen any seeds or chaff which immediately gets sucked into the radiator or rad screen.
/ Driving tractor with the front end loader bucket elevated . #6
I was discing in 5-7 ft tall weeds. I used the bucket to push the weeds over in advance of the tractor. I was still fighting them off in the open cab occasionally
i have noticed people driving with the bucket elevated mowing lawns/pastures fields on slopes and I personally like to keep the bucket close to the ground for stability when not driving on flat ground.
/ Driving tractor with the front end loader bucket elevated . #9
I keep mine on and low to the ground. In taller grass / weeds if there is something I can't see like a tree or something I would much rather it hit the bucket than the tractor.
/ Driving tractor with the front end loader bucket elevated . #10
It can depend on many things.
I mow other people's fields for hire. Some fields I mow, it will be the first time I've ever been on the field. You don't ever get to see it for the first time "already mowed". Some fields, I've been on before, and I "know" the field.
I use my bucket as a tool to "find" surprises in the tall grass and weeds that "no one knows how that got there". I'm pushing the grass and weeds down intentionally with my bucket.
This field had weeds 10' tall in some spots, and at least hood high, all over the field, I'm using my bucket to push it down in front of me to see if "something" is in there:
In this field alone I "found"...
Stacks of pallets
Old vehicle tires
Old tractor tires
Chunks of concrete
Large mound of dirt
Right out in the middle of all these tall weeds, and randomly strewn about. My bucket, running low in front of me, ON PURPOSE, has saved me more times than I can count.
/ Driving tractor with the front end loader bucket elevated . #11
I also run mine low to the ground.
Another thing that gets me is during hay season EVERY tractor I see on the road with a loader mounted hay fork has it tilted back at almost exactly head height. Point the thing at the road people!
/ Driving tractor with the front end loader bucket elevated . #12
I usually have the loader off when mowing but I too use it in unknown territory.
What I don't get is seeing people baling or raking with a 100 HP or more tractor and the loader and bucket are ALL the way up!! For visibility I am guessing, . . but there are some major forces on that poor thing rocking back and forth way up in the air.
/ Driving tractor with the front end loader bucket elevated . #13
Very flat surface area, and grasses less than two feet tall, known area, bucket is up.
/ Driving tractor with the front end loader bucket elevated . #14
Only 1st pass I drive with mower behind me, after that I use the full extend of the ditch bank flail mower and drive in the 1st pass track. It also sucks in way less stuff into radiator when I do it this way.
/ Driving tractor with the front end loader bucket elevated . #15
I keep my bucket elevated to prevent it from bottoming on the uneven ground I mow. If I'm in an area with difficult visibility, I'll remove it.
/ Driving tractor with the front end loader bucket elevated . #16
On construction sites you’ll rarely see moving equipment with the bucket high in the air. Loaders in a gravel pit are different though.
/ Driving tractor with the front end loader bucket elevated . #17
We keep the loader bucket or bale forks rotated up while roading the tractors or doing field work with them on. If pointed down if they contact the ground it is going to cause a lot of damage. With it rolled back it will skid along the ground and not dig in.
/ Driving tractor with the front end loader bucket elevated . #18
My dad ran over an unseen bike with his little ford and a bushog. Made a racket.
/ Driving tractor with the front end loader bucket elevated . #19
I try to stay low. I have to lift it to get through gates when the fork is loaded, however. When I carry a lot of debris, the FEL is usually a couple of feet off the ground to prevent things hanging off of it from catching on weeds and things.
My most fun experience with the FEL came while using a rope to pull shrubs. The rope was not centered, and when the FEL went up, the tractor started rolling onto the side with the rope. The speed of the roll was impressive.
/ Driving tractor with the front end loader bucket elevated . #20
I have noticed some people driving there tractors with the front end loader bucket about 3' to 4'ft off of the ground while mowing or brush hogging and I am wondering why some people do so . I always keep the bucket low to the ground .
I have to remove the bucket to put on the Brush hog. :D
2018 CHEVROLET TAHOE (A66091)
2018 CHEVROLET...
2007 OK TRUCK & TRAILER PRESSURE WASHER TRAILER (INOPERABLE) (A67714)
2007 OK TRUCK &...
PALLET OF HEAVYEQUIPMENT PRESSURE WASHER PARTS (A68842)
PALLET OF...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A67148)
2017 FREIGHTLINER...
PALLET OF HOSE FITTINGS AND HEAVYEQUIPMENT PARTS (A68842)
PALLET OF HOSE...
