L4240 Stalls when the ambient temp is hot.
/ L4240 Stalls when the ambient temp is hot. #21
It's also possible that the electric lift pump is failing. When it's good and hot out, check for fuel flow after the lift pump.
I agree. Sounds to me like your lift pump is failing. Mine are mechanical and driven off the camshaft and easy to replace as well. Not familiar with the electric ones but they fail as well.
/ L4240 Stalls when the ambient temp is hot. #22
well after a few weeks of cool weather, it finally got warm. Tractor was running good while it was nice.
On the first hot day it started stalling pretty bad, when I got back to my shop there was hydraulic fluid coming out of the silver thing (or above it and dripping down) in the pic. Service folks said it most likely some seal on the transmission in there that doesnt go bad often.. of course. I dont remember exactly what he said it was, but required essentially split in half.
Havent heard back yet on the exact issue. But I am guessing the stalling was when the fluid got to a certain temp it would start to leak then stall out.
That is the drain for the bellhousing and if it is dripping fluid, it's indicative of a main seal leaking. If it's engine oil or transmission fluid, only you can tell but either wan it will entail a split to remedy and has nothing to do with your stalling hot issue.
well any of the fixes for this are well above my paygrade, so its in the shop now. I will update when I find out something, I am sure it wont be cheap
it was transmission fluid that was coming out.
/ L4240 Stalls when the ambient temp is hot. #25
Then your input shaft seal is leaking. Least it's not the crank seal leaking because that usually contaminates the clutch if you have a clutch.
Amount is always important because a small amount may be from thermal expansion whereas a large and steady amount means the seal is shot.
/ L4240 Stalls when the ambient temp is hot. #26
Actually this is a known failure point on the Grand L, both the 30 and 40 series. And it may recur in a few years. So far mine has held (knock on wood). The crappy part is you have to split the tractor to get to the one cheapo seal to replace it. Why Kubota let it go all those years without a real fix is beyond me, but probably good old cost.
/ L4240 Stalls when the ambient temp is hot. #27
I knock on wood as well (leaking crank or input shaft seal). Of course neither of my M's have a clutch to get contaminated. All that is in the bell housing is a damper plate to mitigate shock loads during directional changes so if they did start leaking, I'd just keep an eye on the engine oil level or the gearcase level.
Even with nothing inside the bell housing, both still have pin drain on the bottom.
/ L4240 Stalls when the ambient temp is hot. #28
Above my pay grade as well. Considering labor rates (shop time) today, it will probably be a wallet buster. It's all grunt work for the most part, parts will be inconsequential.
One reason why I never use the 'vacuum' method when changing gearcase lubricant. Pulling a vacuum on the gearcase to mitigate spills when changing filters, in my thinking, puts undue strain on all the seals and could cause an expensive failure. I might be 'all wet' on that assumption but I want to be safe, not sorry.
/ L4240 Stalls when the ambient temp is hot. #29
Pretty sure there is no lift pump on the 40series. Gravity feed all the way to the filter.
/ L4240 Stalls when the ambient temp is hot. #30
Not sure actually, I was just assuming in as much as both my M's have mechanical lift pumps, but then my fuel tanks are BELOW the centerline of the crankshaft.
/ L4240 Stalls when the ambient temp is hot. #31
There absolutely is a lift pump on the 4240, not sure about all the other 40 series. It is vacuum operated not electrical as speculated earlier in the thread. I know this because mine failed just before the warranty was up but the issue was misdiagnosed by the dealership which led to a multi month debacle after their "fix" involved taking the high pressure injection pump out of calibration. All for what should of been an $18 part at that time and about an hour to troubleshoot and replace. I'll spare you the long version of the story but I'm no longer as ignorant about diesel engines as I was prior to then.
I do agree the rather common input shaft seal failure requiring splitting the tractor is likely unrelated to the stalling issue. The stalling issue is very perplexing as the ambient temp of ~ 80 degF is really not that warm and stalling from ambient temp and not machine temp isn't something I can recall ever hearing of.
/ L4240 Stalls when the ambient temp is hot. #32
A "vacuum operated lift pump..." on a diesel engine! Where's the vacuum come from? Do you have a separate vacuum pump?
/ L4240 Stalls when the ambient temp is hot. #34
Well that is interesting. There actually are some tricky ways to get a little bit of vacuum from a non-turbo diesel intake manifold - or from any airflow. I think some Mercedes did some of that. It might just be enough differential pressure to work a tiny lift pump. And your L4240 does happen to be from those years (2007 to 2013) when Kubota was experimenting with innovative intakes trying to beat the Interim Tier IV emissions requirement.
I know about weird intake mods because we have a 2008 Kubota M59 from that same era. It came with the most bizarre EGR setup I've ever seen. This EGR is a technical marvel involving a water cooled muffler and a device cantilevered off the back of the engine block with some extra intake manifold valving whose operation varies with coolant temperature - as well as a couple of pages in the shop manual dedicated to explaining how it is supposed to operate. BTW, thanks to Kubota for those pages; they saved me from having to take it apart to figure out what was happening in there...
So a vacuum operated lift pump in a Kubota from those years would be just strange enough to be in keeping with what they were doing back then.
If any of this is real - and there really is a vacuum lift pump - it might simply need a replacement vacuum hose.
Luck,
rScotty
/ L4240 Stalls when the ambient temp is hot. #35
Luck,
rScotty
I am always up for learning and appreciate your response Scotty. Perhaps the more knowledgeable posters can help out here. Item 090 in the L4240 parts diagram below, "Assy pump, fuel". In my paperwork from the repair it is listed as a vacuum lift pump, if not powered by vacuum I am legitimately curious as to the drive mechanism. I do see the part is approaching $200 which is a far cry from the $18 listed on the repair invoice.
/ L4240 Stalls when the ambient temp is hot. #36
I think the "vacuum" is referring to the fact it Pulls fuel to the motor/injection pump from the tank via rotating vanes or a diaphragm, as opposed to pushing it from the tank to the motor. The diaphragm/vanes are driven by either gears or a lobe from either your crank or cam. Some older gas cars had a spring-loaded arm that was moved by a cam lobe. I can't really tell from the resolution, but ... from the pics, the assy labeled 1G896- 52030 MAY have a button on the end that gets moved by a cam lobe. Assy 17121-52033 looks like a flat tab that fits into a slot on some gear -- maybe the same one that drives your high-pressure pump since it looks like it attaches below your injector pump. (look at the non-fuel line sides that need a gasket on the block connection to see if it's a spring loaded button or a flat tab that rotates)
/ L4240 Stalls when the ambient temp is hot. #37
That's exactly how my filter's vacuum gauge is designed to work. A positive displacement lift pump creates vacuum drawing fuel through the filter, through the lift pump, and under low pressure to the injector pump.
/ L4240 Stalls when the ambient temp is hot. #38
The parts picture is a diaphragm pump that is actuated by a cam lobe that presses against a plunger that pushes against a diaphragm. There are check valves in the pump that allow fuel in on the intake stroke and then close when the fuel is pushed out the other check valve and toward the IP.
/ L4240 Stalls when the ambient temp is hot. #39
I believe ou are describing a positive pressure pump, not a vacuum pump. Either will work, although the vacuum type is limited by how high it can pump compared to a positive pressure type. Also, it is unusual to use vacuum pumps on fuels because it causes outgassing from the liquid.
/ L4240 Stalls when the ambient temp is hot. #40
A diaphragm pump creates a small vacuum on the intake stroke to suck fuel in, then a check valve on the inlet closes as the diaphragm moves in the other direction to create a positive pressure (~4.0 to 4.5 psi) and the outlet check valve opens to port fuel to the IP.
The "vacuum pumps" I'm familiar with are used to pull air out of a tank, etc.
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
2014 18ft. Parker Performance T/A Trash Trailer (A60352)
2014 18ft. Parker...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
2013 FORD F250 (A60460)
2013 FORD F250...
