It’s too hot to mow.
   / It’s too hot to mow. #41
Good info on not mowing above 85 degrees for us northern folks; thank you. Hopefully not too much damage mowing yesterday and today the 10 + acres in 90 + heat, mowing VERY slowly with an open cab tractor with no canopy. Kept thinking about the old-timers that worked the fields with open tractors in Arkansas, Texas, etc. and kept telling myself to "toughen up" as I was getting parched.
A deceased buddy of mine that was older than me used to work on road crews in the summer and volunteered for sub zero linemen assignments to avoid his soon to be ex-wife. He was much tougher than me.
And he commented that as he got older, his comfort range started to shrink. He couldn't tolerate the cold or heat as well.
I've found the same for me. I had a strong dose of COVID in July 2020; ever since, direct sunlight of 80 on my bald head feels like its 100. Very strange, since heat didn't use to bother me....
   / It’s too hot to mow. #42
YOU may have 30 minutes of grass cutting, but some of us have acres to cut. Ain't no 30 minutes thing. (plus some medications limit your ability to sweat. No sweat = heat stroke.)
I have a JD X758 60" deck I mowed for about 220 hours last year I will probably mow that many hours or more this year. Then I have some seat time bush hogging as well.
   / It’s too hot to mow. #43
Funny, I guess some are too pampered to do outdoor work without cool aid and AC. I understand some in this forum spend hours working their fields, and a cab w AC is warranted, but I have to laugh when AC becomes a necessity in order for them to get on their lawnmower, with a front loader, and cut grass for 30 minutes.
Laugh all you want my friend, I won't hear you. :D
   / It’s too hot to mow. #44
For the folks like myself that are not cutting hay but using a rotary cutter to clean up around the farm: It is way too hot to mow. In the sun, sitting on a diesel tractor, over 50, overweight one is flirting with a heat stroke. We still do it.
I am 65 yrs old and the heat or cold has ever stopped me but then again I grew up on hay wagons and I now weigh 168 pounds at 6'1" , I drink plenty of water and the sweat and hot weather is good for a person helps you burn calories.
Bring it on.
   / It’s too hot to mow. #45
Bring it on.
I said we still do it...that is, we still work in the heat. For me, it is just getting harder as I get older.
   / It’s too hot to mow. #46
I understand Bud...getting old is not easy is it ? I was carrying an extension ladder the other day and it felt a lot heavier than it did 20 yrs ago.
I take it you don’t have AC?
   / It’s too hot to mow. #49
Heading out to mow right now. It is only 70° right now, but will be over 90 this afternoon.
Oops! That was supposed to be postrd yesterday afternoon. Anyway, I mowed the front yard for maybe an hour, and then the heat build up enough that I quit. Will start again tomorrow because it’s again cooler in the morning.
Super hot days up here will be over effective Friday. Still a fire ban in effect, meaning this week’s renters will not be allowed to have a fire in the fire pit. They won’t be happy, because the fire, pit is a big attraction!
2019 Freightliner M2 106 8.5 CuYd Street Sweeper Truck (A53422)
2019 Freightliner...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
Giyi 44" Mini Excavator Root Rake (A56469)
Giyi 44" Mini...
2014 Ford F-150 Pickup Truck (A53422)
2014 Ford F-150...
2012 Ram 3500 Crew Cab Flat Bed Truck (A53422)
2012 Ram 3500 Crew...
2005 Peterbilt 387 with Wet Kit (A57024)
2005 Peterbilt 387...
