It’s too hot to mow.
   / It’s too hot to mow. #31
'Cud' is the clumps of damp grass the mower leaves. Mulching blades are especially prone to 'cudding'.
um, no... unless this a slang for your area. Or maybe you chew your... cud. LOL
   / It’s too hot to mow. #32
Curious, as I have gotten older I can take the cold better than the heat. Both extremes are more difficult than they used to be.
How about the rest of you?
   / It’s too hot to mow. #33
Funny, I guess some are too pampered to do outdoor work without cool aid and AC. I understand some in this forum spend hours working their fields, and a cab w AC is warranted, but I have to laugh when AC becomes a necessity in order for them to get on their lawnmower, with a front loader, and cut grass for 30 minutes.
YOU may have 30 minutes of grass cutting, but some of us have acres to cut. Ain't no 30 minutes thing. (plus some medications limit your ability to sweat. No sweat = heat stroke.)
   / It’s too hot to mow. #35
heh... people talking about being too hot, while sitting still on a mower or tractor. I'm moving and leveling another 20,000 lb. of crushed stone today. Did 20,000 lb. over the prior two days, and 40,000 lb. last week. Stay hydrated, pace yourself, and keep moving forward.
   / It’s too hot to mow. #36
Come up here in the winter if you want to experience REAL cold.
Heh. Western, northern, or UP maybe. SE tends to be much milder although we have had a few bad ones.
   / It’s too hot to mow. #37
I mowed our acre of grass at around sunset last night and it wasn’t too bad. Today, I bushogged (3) small hayfields, sitting under the canopy of my tractor, and it also wasn’t bad, at a clip of about 10 mph, in 6th gear, at pto rpm.
   / It’s too hot to mow. #38
Don't mind little heat but humidity (n)
   / It’s too hot to mow. #39
I've only mowed once this summer. And that was because it actually rained one day so I did a mow the day after.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
20FT X 12FT LIVESTOCK SHELTER (A58214)
20FT X 12FT...
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
Set of Heavy Duty Steel Trailer Ramps, 60" Long (A59076)
Set of Heavy Duty...
CASE MXM 190 TRACTOR (A58216)
CASE MXM 190...
Rhino HB78 78in Box Blade Tractor Attachment (A55973)
Rhino HB78 78in...
