Three Point Draw Pin Nut keeps coming off - how to secure it
/ Three Point Draw Pin Nut keeps coming off - how to secure it #1
Kioti CK3510
I've been running my Kioti CK3510 for a few years with a land pride brush hog attachment. Suddenly, this summer, I have destroyed three of the lower 3-point draw pins. The cause is the same each time. The 7/8" nut vibrates off during mowing and with it goes the large 7/8" flat washer and matching lock washer. The pin then rattles around in the hole until the threads get destroyed. It's always the same pin, always on the left side of the tractor.
I have taken to buying these pins in bulk at my local tractor place. I'm a big guy and have torqued the heck out of the nut before running the mower. I even put some loctite blue on the threads once, still the nut vibrates right off.
Any suggestions as to what I am doing wrong? See photo taken after hosing down the tractor this morning after mowing for about an hour. The nut and two washers are just GONE.
I'm about ready to spot weld the freaking nut in place, but hopefully there's a less drastic solution.
This is clearly a case of a "loose nut behind the wheel." Thanks in advance for your assistance.
Thanks,
Mark
North Idaho Cat Juggler
YouTube: @catjuggler333
/ Three Point Draw Pin Nut keeps coming off - how to secure it #2
Put locktite on the threads and use an impact gun to tighten the nut with a heavy duty split ring lockwasher between the frame and the pin.
/ Three Point Draw Pin Nut keeps coming off - how to secure it #3
I see a ton of space between the saddle of the QH and the pin. Are you supposed to be running bushings? Is that a CAT II hitch with CAT I pins on the cutter? Something is not right there. That wobble and slop are probably what's causing the nut to loosen.
/ Three Point Draw Pin Nut keeps coming off - how to secure it #4
Do as 5030 and then run a second nut behind the first and lock them together.
You could also drill a hole and put a cotter pin to hold the nut from backing off. Use a castle nut just like a trailer axle.
Thanks for the speedy suggestions. It's a cat one Quick Hitch. No bushings needed to adapt Cat 1 pins. The photo is taken with the 3-point completely lowered. When in use the pin rests correctly in the hitch. This has also been working fine for years and just suddenly started being a problem. The right hand pin is original and has never worked loose.
/ Three Point Draw Pin Nut keeps coming off - how to secure it #6
All of that may well be true but the spring loaded keeper on top should engage the top of the pin with little to no space or play. That would drive me nuts. There are a dozen easy ways to keep a nut on but that slop needs to be removed. Probably doesn't matter as much with a bush hog or FM but you couldn't run it like that with anything else.
/ Three Point Draw Pin Nut keeps coming off - how to secure it #7
I would have said it needed a bushing also looking at the slop. My thought is that the hitch is grabbing the pin while your raising and lowering the brush hog which is rotating the pin to loosen the nut.
/ Three Point Draw Pin Nut keeps coming off - how to secure it #8
drill it with a 1/8 bit and pin it
/ Three Point Draw Pin Nut keeps coming off - how to secure it #9
While the one on the left is getting loose the one on the right is probably getting tighter and tighter. Yep, clean it and loc-tite it...forget it.
/ Three Point Draw Pin Nut keeps coming off - how to secure it #10
I would consider a larger diameter pin or bushing. Less slop. Then LokTite with a double nut. I think workinonit has identified the problem. The top spring loaded keeper is not engaging the top of the pin. Too much slop.
/ Three Point Draw Pin Nut keeps coming off - how to secure it #11
Definitely a problem with the pin moving up and down in the saddle. looks like to me the thread needs to be bigger because there is a lot of slop around the threads in the A arm part of the attachment. That will also allow a rocking motion to loosen the nut.
/ Three Point Draw Pin Nut keeps coming off - how to secure it #12
Thanks,
Mark
either ditch the flat washer or put it on the shoulder side of the pin. the flat washer does not protect the base metal, it prevents the lock washer from biting in and locking the nut to the frame.
Thanks for your comments thus far. To clarify some points I have uploaded additional photos. 1st photo shows left side to reveal the size of the draw pin hole in the Land Pride RCR1260 mower. 2nd shows the right hand side pin as it was installed by the factory (or the dealer?) and it's never worked loose nor has it ever been removed. 3rd photo shows side view of the right pin to detail the lack of clearance for a bushing. All photos in this batch are with the 3-point hitch raised up with the mower fully suspended.
1) The flat washer is required, because the draw pin hole in the Land Pride mower is so big that the lock washer alone would be swallowed up by it.
2) The Quick Hitch is a Speeco Cat 1 E-Hitch, and based on photos of the product on the site where I bought it, it's designed this way. Design flaw? There's no room for a bushing as the quick hitch is designed specifically for Cat-1 pins.
3) If wobbling of the pin is working it loose due to suspected design flaw in the Quick Hitch, why has the right pin never wiggled loose?
At this point I'm leaning toward going with the castle nut and cotter pin, loctite and torqued on with an impact hammer.
Thanks again for your analysis and comments.
-Mark
Edit to add: Checked the manual and confirmed, I'm missing a bushing (part #4 on manual scan I just uploaded) around the threaded portion of the pin.
/ Three Point Draw Pin Nut keeps coming off - how to secure it #14
-Mark
can’t answer why on the right, however can opine on what you’re showing. the implement hole is way too big for the pin shank. Even when tight, it will eventually elongate the hole and wear it out. what is the diameter of the hole?
/ Three Point Draw Pin Nut keeps coming off - how to secure it #15
First photo of those three shows a hole much larger than the pin. You could try measuring the hole and look for the right bushing on Amazon or McMaster Carr to reduce the play.
/ Three Point Draw Pin Nut keeps coming off - how to secure it #16
-Mark
Hopefully you will be able to buy the correct bushing from your local dealer, if not you might be able to remove the bushing from the other side and have a machine shop make you a new replacement bushing.
/ Three Point Draw Pin Nut keeps coming off - how to secure it #17
Glad you found the missing bushing in the parts diagram!
Found the parts manual and got the part number for that missing bushing. In case anyone happens upon this thread in the next few years with the same dang problem, for the sake of completeness it's Land Pride Part# 327-437D. The bushing is 1.25" OD x 0.89" ID x 0.56" Long.
Thanks for all the help!
Mark
/ Three Point Draw Pin Nut keeps coming off - how to secure it #19
If that QH is designed for the pins to fit so loosely in the saddles you may never get that left pin to stay tight without securing it somehow. That's a poor design for sure. The spring loaded keeper should contact the pin at all times and not allow it to move at all. As for the right side, it is being tightened as the left side is being loosened. Both pins are right hand threads.
2016 Godwin CD225 Silenced Dri-Prime T/A Towable Trash Pump (A61567)
2016 Godwin CD225...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A62130)
2006 FORD F-450...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
PALLET OF 12 IRON GATES (A60736)
PALLET OF 12 IRON...
3 headed Indian statue (A61569)
3 headed Indian...
