Pictures from a skid steer mowing contractor
   / Pictures from a skid steer mowing contractor #71
Currious @ptsg have you ever run a track loader with a cutter out front?
No. I've seen them working and it was enough for me.
Have your even ran a chain brush cutter with a tractor?
   / Pictures from a skid steer mowing contractor #72
Most people don’t buy a skid steer for the sole purpose of running a mower. Buying a cutter for a CTL that you already own is a lot cheaper than buying a dedicated setup. I already have a skid steer for my construction business and a $6,000 cutter turns it into a pretty capable brush cutter. A forestry tractor would be dang near useless for the rest of my needs. If you already own a tractor you’d probably buy a tractor mower but a tractor needs tens of thousands of dollars of shields to be used like that where the skid steer is a lot more capable in stock configuration.
I didn't say people would buy a skidsteer just for mowing. I said people pay crazy prices to have a skidsteer doing mowing for them.
Obviously, you're a contractor and run a skidsteer for other types of work. That's about the only time I've seen skidsteers mowing in this side of the pond, only because there was like 10% mowing on that job and 90% dirt work.
As far as shields go, for a cab tractor, sure. It may need some more protection to push branches away and possibly a skidplate, definitely not tens of thousands of dollars. For a ROPS tractor, maybe a simple skid plate at most for those guys that like plowing through everything with the tractor.
With that $6k you say, you could buy one of the best chain cutters here and still have $3k to spend in shielding. If the guy operating the tractor knows what he is doing, he will hardly need any shielding though. That chain skirts on the mower will be plenty enough.
It's pretty obvious that some folks here have never seen a chain cutter working, let a alone a tractor working in the woods with it and how well it will actually move, probably because they think its needs an huge tractor with an oversized cutter to get anything done. That's perfectly fine. I'm just gonna say, you would be surprised.
   / Pictures from a skid steer mowing contractor #73
Very insightful, guys, thank you for your honesty. I've often wondered what to charge for tractor work - if ever asked.
   / Pictures from a skid steer mowing contractor #74
Ptsg could you mention a couple of manufacturers of the chain cutters? I'd like to do a little web searching but I don't think I'd get far with just a description. 👍
   / Pictures from a skid steer mowing contractor #75
I know mostly Portuguese ones. I believe most will have an English option on their websites.
Agroramoa
Bermathor
Joper
Galucho
Herculano
Herkulis
Agriduarte
Picursa (Spanish)
There are bunch more but for the most part only offer light duty versions.
   / Pictures from a skid steer mowing contractor #76
No that's why I'm not saying they are better or worse than skidsteer. I have run tractors with a bladed brush cutter. Also the prices I quoted was for a trackloader with a drum mulcher not a rotary cutter.
   / Pictures from a skid steer mowing contractor #77
Back to the chain mowers. What size chain do they use?
Can you buy a chain blade brush hog for a skid steer in the USA?
   / Pictures from a skid steer mowing contractor #79
You ought to have that $200 bushhog spinning chains already;)
Lol - I am gonna try to do that. Maybe pick it up this long weekend.
Model 12 brush hog specs look pretty good. Nice thick steel housing incase my experiment goes bad. Chains fly off at 12k fpm
Gearbox 540 RPM (65 HP) Blades 1/2” x 4” Blade Tip Speed 12,193 fpm Blade Holder Round Top Deck 7 Ga. Steel Side Bands 1/4” x 6”
Looks like it will only take 12" of chain. Hopefully we can do this without F-ing the model 12 up.
   / Pictures from a skid steer mowing contractor #80
1/2" grade 80 chain will be good size for that size of mower. 5/8" would work too if you really want to hit something hard.
Don't be surprised if you hear a loud bang when starting up the mower, specially if your tractor has electric over hydraulic PTO control. It's just the chains hitting the deck.
I've broke a link before on my mower and it landed exactly where it broke. I see it no different than breaking a blade. If anything, it has less mass.
2019 Harley Davidson 114 Police (A50324)
2019 Harley...
2019 Isuzu NPR-HD 24ft. Box Truck (A50323)
2019 Isuzu NPR-HD...
2002 International 4400 SBA 4x2 Flatbed Truck (A49461)
2002 International...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A52128)
2000 John Deere...
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
