TC45DA Electric Two Speed
   / TC45DA Electric Two Speed #12
What I am pointing at is this part #SBA340015990.
Yes that is the HI/LO Solenoid Valve... should be 2 wires coming off the round Solenoid that have bullet connectors on them connecting them to the harness... The square part is the valve block & has the hydraulic piping going to it.
It’s interesting that NH shows it is for both gear and HST tractors and some loaders.
I wonder what i is used for on a gear drive tractor? On loaders I guess it’s for a third function.
   / TC45DA Electric Two Speed #14
@dieselscout80 - not sure the reason for that but here is the excerpt from the Service Manual...
  • New Holland TC40 HI-LO Solenoid Valve.pdf
Well we been busy with wind storm damage, vacation and getting a new home HVAC system.
Monday I was cleaning up the down tree limbs and tried the high/low switch again and it worked fine even though I hadn’t done anything to fix it and it worked on Tuesday too. I guess I‘ll just monitor it.
   / TC45DA Electric Two Speed #16
Glad it started working. Like was said, it is in Low unless the Hi/Low solenoid is activated. In case it happens again, here is what the service manual says.
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
Badger Silage Wagon (A50775)
Badger Silage...
2015 Ford Focus (A51694)
2015 Ford Focus...
2016 Chevrolet Cruze Limited Sedan (A53424)
2016 Chevrolet...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
