While the old fashioned way may tell you it is past time for a change, oil analysis by a reputable lab is more sensitive, accurate, and reassuring. I use Blackstone Labs for both crankcase(s) and hydraulic oil. Following their recommendations I've had no mechanical problems with extended change intervals. (No commercial relationship with the lab beyond paying about $30 per analysis.)The old fashion way was to have a look at the oil, if it's getting a bit black, or it looks a bit milky, or you can feel it a bit gritty when you rub it between your fingers, then maybe it's time for a change. But if it's nice and clean and slippery, then maybe have another look later.
Draining hydraulic oil into a pan in one shot means having a pan that holds 13 to 15 gallons and then having enough lip on the pan so as to be able to slide that monster out from under the tractor.
Not everyone has such a huge oil pan. Or can handle the weight. And once you've got that pan successfully out from under the tractor without making a mess, how do you empty it? And into what?
That pan of oil now weighs over 100 lbs....
The initial (50 hr) filter change on the M6040 taught me a lesson.
For the next one I parked the tractor with as much of a side tilt as I dared, and lost a lot less fluid. It also helps to have a second magnet ready so time isn't spent on cleaning off the one that was in there.
I used NAPA filters that time, so had to reuse the magnet. OE filters seem to come with it.My last filter change didn't have the magnet on the new filter, so maybe the L4060 hydraulic filter doesn't come with them anymore?
Hello all,
I have a new Kioti CX 2510. The manual states to change the hydraulic oil at 400 hrs. Does anyone recommend changing that oil sooner from their past experience, or will hydraulic oil remain stable for 400 hrs with regular filter changes ? Thanks for reading.
Sonny101
