Help identifying couplers for skid steer and kubota tractor
   / Help identifying couplers for skid steer and kubota tractor #11
Check places like Discount Hydraulic Hose or Summit hydraulics. They should have that kind of stuff easily.
   / Help identifying couplers for skid steer and kubota tractor #14
Yeah, but I want to try to minimize adapters, if possible.
Thanks,
Chris
Adapters are cheaper and easier than getting new hoses that fit. Especially if they have to be custom made for the purpose.
There's nothing wrong with using quality adapters, and it looks like there was one already so it should only be a matter of using the correct one instead.
I am researching the pioneer ends right now, trying to figure out what thread options there are for those, since I'd like to stay away from NPT if possible.
   / Help identifying couplers for skid steer and kubota tractor #16
That I don't remember, but if they aren't listed on Surplus Center's web site, they may not exist.
Any particular reason you don't want to use NPT thread?
I was reading that the industry has decided they are not good for high pressure applications, and this seems to be backed up by the fact that what I have now doesn't use any NPT threads. Just figure I'd try to use something different, and maybe more reliable, if possible.
Thanks,
Chris
   / Help identifying couplers for skid steer and kubota tractor #18
Fair enough. Even though there must be many millions of NPT connections in use that work just fine in high pressure applications.
Maybe you could switch the couplings over to flat faced ones? I much prefer those over the cheapy standard tractor couplings. Much easier to keep clean, no fluid loss, etc.
Wish I'd done it while I still had money, and nowhere near as many quick disconnects. They are a bit pricey, especially these days.
   / Help identifying couplers for skid steer and kubota tractor #19
I found, on the grapple side, 18mm-1.5 straight female threads with an o-ring. I am not sure what this thread configuration is called, as it isn't NPT.
I'll head up to tractor supply to see if they have anything.
Tractor side, in thumbnail. I suppose they are "pioneer" style.
This is the skid steer side, coupler on the left and hose end on the right:
That threaded end looks like a DIN fitting.
Well, I have read that releasing the pressure, if needed, on the flat-faced couplers is very difficult. I know that with the poppet type you can bang them against something hard and get a release out of those.
I have not had a problem with the poppet type, yet. I have them on the valve block of the FEL and on the bucket end of the loader.
Not that I know much about this, but what I have been reading does make sense.
Thanks,
Chris
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52128)
Koyker Loader...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
