LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,710
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Well got my new little Kioti Tuesday this week haven't had much time to do anything to speak of with her yet.
Sitting on the trailer when delivered I could see that the tires were over inflated. Yesterday evening I got around to checking
them, damn what a surprise. The dealer that I got it from has been a long time dealer through a couple of generations
it started out many years ago as a New Idea implement dealership. Now days it's got about 3 dealerships and handles Kioti,
Kubota, and Yanmar tractors. They have been a lawn and garden size dealer for many years, but not large ag.
The rears on my tractor as found were over filled with beet juice and over inflated at 40 PSI, I drained juice out till I got them down
to 25 PSI on the rears and they were still pouring out beet juice. The R14 tires are labeled max pressure 30 PSI for the rears,
the fronts are labeled max pressure 44PSI and they had them at 25 PSI. Seems to me that whoever they stuck with the prep work
isn't very well versed or trained in their job and may have likely gotten the inflation pressures reversed.
This was the first time I've messed with filled tires on a tractor with a backhoe mounted as I was finishing up last night, it
dawned on me that I was not doing this the smartest way. I should have lifted the rears just off the ground or at least enough to unload them
and then just pulled the valve core section out of the stems and let the beet juice pour out till it got down to the level of the valve stems
then just aired the tires up to 20-25 psi. May still do so later on.
I was amazed at the traction the loaded R14's with the backhoe still mounted, it was very good. I'm still a bit disappointed with the travel speed of the 25 hp tractor.
The performance of the AC and the placement of the air vents is very good.
I'm still having to get used to moving my feet to switch from forward to reverse, after so many tractors with left hand power shuttle or reverser levers
moveing my foot and pressing down is a bit different, I find myself reaching up with my left hand frequently.
