m5040
- Joined
- Nov 23, 2008
- Messages
- 1,023
- Location
- CT
- Tractor
- Kubota M6040 L2250, JohnDeere 310D, Ford 841 Elenco, Ford 961, Trapmaster, PT180 w/LM bucket and 45" brush cutter, PT1430 Deutz w/grapple bucket, Antonio Carraro Tigrecar 6500. John Deere 5300. Former owned Steiner 430 max, Goldoni REV Maxter 7
A suggestion for easier disassembly. Use a quality brand of Never Seize when you disassemble anything. It keeps exhaust parts free for years and dissimilar metals too. It can also be used to protect areas when welding as it seems the molten weld won't penetrate it (do your own test with that). What I mean by that is if the bolt/stud is broken off below the surface, you can Never Seize the tread area and weld up to the surface without damaging the parent material.
JUST KEEP IN MIND THAT WHEN YOU COAT A FASTENER WITH NEVER SEIZE YOU HAVE TO REDUCE THE TORQUE SPEC BY 30% due to the lubrication.
