The one thing that you wonder why you didn't buy sooner?
/ The one thing that you wonder why you didn't buy sooner? #42
35 gal fuel caddy makes filling the hard to reach fuel tank on my l4150 no longer a messy balancing act holding a funnel and fuel can chore. rattle canned yellow sharpied diesel on it, and added aftermarket fuel filtration. Can fill both my Kubotas and mini x 2x + before I need to refill caddy.
/ The one thing that you wonder why you didn't buy sooner? #43
Tractor. 25 gallon 10’ boom sprayer for the ATV. Cordless impact wrenches and torque wrenches
/ The one thing that you wonder why you didn't buy sooner? #44
Bush Burro ATV trailer. I have used it to haul wood, dirt, rocks, friends, killed game, darn near everything. But also the impact driver and tractor are up there too.
/ The one thing that you wonder why you didn't buy sooner? #45
Small battery operated circular saw. So much lighter than the regular size, charge lasts for a lot of cuts and actually bought it for my wife. But I like it so much, my regular sized one is in it’s carry case and doubt it will ever come out.
/ The one thing that you wonder why you didn't buy sooner? #47
I'm really poking myself for not getting a hook-a-roon 35 years ago. What a back saver when working up fire wood. I thought the pulp hook was the end all back then. I recently have proven myself wrong.
If you burn wood for heat, get one!
/ The one thing that you wonder why you didn't buy sooner? #48
My WoodMaxx WM8-H. Hands down. I have had it about six or seven years now. I agonized over it for a couple years before buying. I chip almost everything from fencerows, orchard, standing trees limbs, blow down. I don't build bigass brushpiles to burn. I can hook and unhook in a matter of minutes with my Pat's quick hitch and be ready to rock and roll in no time at all. It has been a great machine for me. Other thing is top tier pressure washer from Northern. I screwed around with those gypo electric jobs you can buy anywhere that don't last worth a hoot. Big diff from the 89 dollar special to the 1300 dollar Honda/Cat pressure washer. Yabo!!
/ The one thing that you wonder why you didn't buy sooner? #49
For tools it would be my Stihl AP battery blower…
It was an afterthought since already had the charger and batteries.
Never knew I needed one or would use it often.
/ The one thing that you wonder why you didn't buy sooner? #50
I think someone may have already mentioned one, but since I used it another half-dozen times over the last week, I'm calling out my Bosch StarlockMax oscillating tool. I was mostly doing interior carpentry back when I bought it, so I got the highest-power corded option they had at the time. But lately I seem to be using it outdoors more and more, and wish I had a cordless version. Might have to buy another one. :)
Somehow I made it through nearly 40 years of life before realizing how damn useful this tool is, for all of those jobs that require a lot of time and elbow grease. It's most useful for undercutting door casings when changing flooring thickness, but this weekend's job was carefully plunging into several buried PVC conduits, believing I had identified which of the bunch were unused versus containing wiring, but never quite sure until you cut. With the Osc, you can carefully scarf out a window and peak inside, before commiting yourself. Since I already had it out in the yard, I also used it for cutting a bunch of drain pipe and even PVC conduit, and found it does a nice clean job of that. Better and easier than the classic hack saw or recip saw.
/ The one thing that you wonder why you didn't buy sooner? #52
Victorinox Swiss Army Cybertool M.
link
I spent about 45 years without one, about 40 of those carrying a pocket knife, leatherman, etc,
The Cybertool fulfills most of my "small tool" needs. First thing in the pocket when I get up, last thing out when I go to bed.
/ The one thing that you wonder why you didn't buy sooner? #53
I can't do one.
1) FEL
2) air compressor and tools
3) electric grease gun
4) Golf cart for around the house
/ The one thing that you wonder why you didn't buy sooner? #56
My pantograph has been around 25 years or so now but I sure wish I had made it decades before I did. Sure it took an entire Saturday to build but has made many metal projects take much less time to build and saved countless grinding wheel lives.
/ The one thing that you wonder why you didn't buy sooner? #57
I have two different creepers. I changed the oil in my truck today and use this pad more than the creepers by far, mainly because it’s lower to the ground. I also sit on it a lot as its padded, such as when doing brakes.
/ The one thing that you wonder why you didn't buy sooner? #60
My Woodland Mills WG24 stump grinder. I had always hired the professional grinders in the past so I had a tendency to wait until I enough stumps to justify the cost. Now I can grind at my leisure and limit the damage I was doing to my mowers and weed trimmer.
