power beyond plug for yanmar 336D part
/ power beyond plug for yanmar 336D part #1
AlanWs
Yanmar 336D
does anyone know where i can find a replacement for 336 D yanmar power beyond plug . yanmar no longer supports part beyond 1990.
/ power beyond plug for yanmar 336D part #2
? what does a power beyond plug do, and where does it go?
Are you talking about a fitting that makes a control valve power beyond.
Yes. One of the power beyond fittings has a pin hole leak. I can't find a replacement and I'm willing to replace the hydraulic directional controller if I can find one thst is compatible.
/ power beyond plug for yanmar 336D part #4
Several of the larger size USA imported Yanmars with built-in power steering also had a power beyond outlet available as part of the 3pt plumbing. If so, it would be below the seat on the right hand side. Not sure if that applied to the YM336D, but worth investigating.
There are several active vintage Yanmar groups - many of the same members in all.
Try re-posting right here on TBN at:
rScotty
rScotty
Thanks for your response. I need to replace the power beyond fitting that attaches to the directional controller. I'll try the group you mentioned to see if they can steer me to someone who may know where I can get one.
