Pto length
/ Pto length #1
Oldstuff
Missouri
'63 Ford 2000
I will likely purchase a king Kutter 5 ft tiller soon and my Kubota L3400 has a quick attach and am wondering if the pto shaft that comes with the tiller will be long enough. Can anyone help with this?
Thanks
/ Pto length #2
Generally speaking, the shaft is a stock shaft that you cut to fit your tractor.
/ Pto length #3
Measure from your tractor pto stub (where it locks in) to the lower pins of your quick hitch. Bring a tape measure when you buy your tiller, stretch out the shaft to where it would connect to the tractor, and see how much overlap you have.
You can also add a pto adapter as discussed in this TBN thread if the measured overlap is not sufficient.
https://www.tractorbynet.com/forums/threads/pto-drive-shaft-overlap.252432/
There is considerable discussion on what an adequate overlap is... I have always considered 6" to be a reasonable minimum, but some state that 1/3 of the shaft length is the required minimum.
/ Pto length #4
When you figure your PTO shaft length remember when the implement is raised the PTO distance decreases. You must be sure when it is raised it does not put thing into a bind.
/ Pto length #5
If it does, it will destroy either the input bearing on the implement or the pto support bearing on the tractor. Usually the latter.
New/Unused AGT YSRT14 Mini Skid Steer (A65583)
New/Unused AGT...
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
Bobcat E80 (A64126)
Bobcat E80 (A64126)
MacDon 963 Draper Header (A63688)
MacDon 963 Draper...
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
1994 Aeromax Semi Truck (A66285)
1994 Aeromax Semi...
