John Deere 54" walk-behind
/ John Deere 54" walk-behind #1
12Bravo
Gold Member
Eastern TN
Kioti CK2610 TLB, Gill 5' Scraper Blade (Tilt/Angle)
Moving on to another project while waiting on Kioti parts.
My wife has this mower that is in need of a LOT of work. Being that is has a 17HP Kawasaki and from my understand this is a good motor.
I've pulled the carb and cleaned it and put it all back together. The jet that's inside the bowl, main jet I think, isn't set correctly. I'm having trouble finding this setting.
Would anyone know how far this jet needs to be screwed in or backed out?
I didn't take the carb apart or I would of counted where it was set.
Part number for carb that's on it is: AM122852
/ John Deere 54" walk-behind #2
In the stem? The main jet is turned in all the way- snug, no adjustment.
/ John Deere 54" walk-behind #3
I'm with tp.
Generally, jets go snug, a needle (to go in a jet or other orifice) may adjust.
Thank you
I wasn't sure
I got a spring for the throttle return, so hopefully this think will run right.
Thanks again
/ John Deere 54" walk-behind #5
Usually the jets are screwed in tight. Does it have a float? Often the float has a setting for it, sometimes a certain sized drill bit under the float with the carb upside down.
It has a float, I snugged it up and will have the new throttle spring on tomorrow and see how it goes.
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
1999 GENERAC 99A GENERATOR (A64280)
1999 GENERAC 99A...
2012 Gehl DL11-55 11,000lb. 4x4 Rough Terrain Telehandler (A61572)
2012 Gehl DL11-55...
2014 KUBOTA SVL75-2 SKID STEER (A64279)
2014 KUBOTA...
VDF-ROTA CENTER LATHE (A64280)
VDF-ROTA CENTER...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
