The Life of a Custom Mowing contractor
   / The Life of a Custom Mowing contractor
Well, it finally happened. We got rain today. First measurable rain in about 6 weeks.
I knew it was coming, so I did some rebaking of a few broken bales and some cleaning up before it hit. Here’s the first drops on the Magnum’s hood at about 1:30 today
Once I got these small rows baled up, I stacked bales we made over the weekend. Great to get some rain.
Tomorrow should be a big cutting day. I have a 40 acre farm I’m heading to.
   / The Life of a Custom Mowing contractor #102
That power line tower looks like it is going to tip over. I assume the land is sloped. Jon
Yeah thats a steep hillside for sure. Sometimes when a bale comes off the chute, it’ll pop an outer string because of the stress it puts on the bale.
   / The Life of a Custom Mowing contractor #104
A few pictures from an underbrushing job with the skid steer today, and just for you Eddie i added a couple of pictures of my forestry mowing rig. Hay Dude if you want me to start another thread I can, I am not trying to take your's over just thought some different type of mowing might make it interesting.
And on to the next place. This one is about 45 acres in 4 pastures.
Today was the first day in a long time I plugged the mower. I started a little too early and last nights rain was still down low in the grass. We got 3” of rain. It was a bit lodged, too.
Once afternoon hit, mowing became much easier.
Had a visitor. The local Railroad
Mowed until about 8PM. Tough start to this day with the mower plugging, but the day ended pretty well. Hopefully will finish this property today, but chance of rain.
   / The Life of a Custom Mowing contractor #106
Does the Kubota 75 require DEF ?
   / The Life of a Custom Mowing contractor #107
The hay mowers and field mowers seem to be pretty trouble free (knock on wood).
You had to go there 😆
I'll knock on wood with you!
We're wet for the past 2 weeks or more and it's in the forecast for the next couple.
The friend I help out when I can makes silage rounds but it still needs a few hours of sunshine before bailing.
Looking good HD!
   / The Life of a Custom Mowing contractor #108
I find your pictures amazing so I would recommend you start your own thread.
   / The Life of a Custom Mowing contractor #110
No DEF on the 75 which seems to be a more reliable setup than the def on the larger machines. It’s also about the top end of what you can haul without a CDL.
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
Kubota L3130 (A53317)
2006 Magnum 125 125kW T/A Towable Diesel Generator (A53421)
2006 Magnum 125...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Bus (A55852)
2000 Thomas Built...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
Flat bed utility truck with inline 6Cy engine (A55315)
Flat bed utility...
