Good morning!!!!
   / Good morning!!!! #171,611
With twins, you need to use a coax the same length as the co-phased coax you will be eventually using and mount one antenna and the extra single coax and match that antenna. Then transfer the single coax over to the second antenna and match that one. 1.1 to 1 is optimal, BUT you will get out better with a bigger mismatch but that is more stress on your finals. After both are matched, then connect the co-phased harness and you are off to the races. Yes, it is a huge PITA.
Got the grass all cut except for on top of the whitby bed, I am going to let the sparse grass on it go to seed, then cut it in the fall. The thermocell kept the mossies and blackflies at bay but it does nothing for the deer flies.
Just got out of the shower and am going to do what I did last evening.
I use bug balls for the deer and horse flies around the pool.
I brush it with sticky stuff, very messy, but they are now covered in flies and we get a break.
   / Good morning!!!! #171,612
Twice as much coax to stuff under the dash to maintain proper length, too…
   / Good morning!!!! #171,614
60F cloudy.
Had couple quick heavy down pours while trimming AM :eek: decide to mow main lawn went well,almost finish mowing front field and down pour came in fast :oops: 20 mins seating under maple trees able to finish mowing,next field mowing ground will have to dry a lot.
Plans for the evening haven't decided yet.
Enjoy your evening all.
   / Good morning!!!! #171,616
I was told when I went to Michigan I should make sure i get one of these, and
for sure some fresh/frozen sour cherries to take home.
I got a lot done today, but not everything. Job security for sure.
sprayed the driveway weeds with roundup, sprayed some mint bug spray around the rv, that smells nice.
am expecting to have a quiet night in. I know there's a bowl of strawberry ice cream waiting for me.
   / Good morning!!!! #171,617
Good (Sunday) morning. Overnight Low (actually, dawn) of 4.5C and it's presently 7C. Calm with light, high cloud cover.
Yesterday, Penelope the Pussybeast came 'in' with a mouse (she's a very good "mouser")... I have yet to find the carcass. :D
I'm off to Church in a half hour and then the rest of the day is His... although, with the wind finally dissipated, I may get a chance to clear some wattle branches & such.
   / Good morning!!!! #171,620
Every summer Blue Bell makes a limited run of this delicious ice cream.
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
Clemco 150psi Portable Sand Blasting Machine (A55973)
Clemco 150psi...
2014 Chevrolet Impala LT Sedan (A56859)
2014 Chevrolet...
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
2015 Volkswagen Jetta Sedan (A55758)
2015 Volkswagen...
2011 JACK COUNTY 130 BBL VACUUM  TRAILER (A58214)
2011 JACK COUNTY...
