Kubota UDT or gear lube for front axle case
   / Kubota UDT or gear lube for front axle case #11
for as small as your tractor's ft axle capacity, you could always use full syn 75/90 hypoid gear oil. Mobile & Vavoline have good ones.... now for your tranny & hyd, if it's hst, i'd stay w/K udt2 or above above, etc.
the syn 75/90 for ft axle will give you added benefit esp @ your location over conventional 80/90, & ensure the axle vent is working...regards
   / Kubota UDT or gear lube for front axle case #12
I use GL5 gear oil in both my M's front axles, always have and it gets cold here and it's a non issue. I use it because it absorbs the shock load better than the thinner UDT or SUDT.
Yes I have 3 QTs of Valvonline synth 75-90 already on hand so just need to source an additional gallon of it to do the service.
It gets really cold here but I use my trucks with 75-90/140 in them more in the cold Without issue. So I think it should be fine.
   / Kubota UDT or gear lube for front axle case #15
sounds you're on top of it, that's what i'd use.
   / Kubota UDT or gear lube for front axle case #16
I lost 4wd front wheel bearings using fluids rather than gear oil on a new tractor doing heavy work. Installed gear oil and haven't looked back.
The brand of tractor having the problem recommended fluid at the time of mfgr.....2007. In 2016 I bought another, smaller tractor of the same brand and gear oil was in the Operators Manual AND MOLDED INTO THE FRONT AXLE FILL PLUG was 90w......questions??????
   / Kubota UDT or gear lube for front axle case #17
I'm going with synthetic gear oil in mine, and I'm in a colder region.
Also, 3 quarts sounds low to me? Mine's almost 2 gallons.
   / Kubota UDT or gear lube for front axle case #20
I use Mobile 1 75/90 syn in my front axle on my L3540HSTC and my B7100DT. I use SUDT2 in both transmissions.
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
2005 IC Corporation PB105 School Bus (A54814)
2005 IC...
1997 CATERPILLAR 322BL EXCAVATOR (A52707)
1997 CATERPILLAR...
8ft Fork Extensions (A55851)
8ft Fork...
2024 78in Hydraulic Brush Grapple Skid Steer Attachment (A55851)
2024 78in...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
