Kubota UDT or gear lube for front axle case
   / Kubota UDT or gear lube for front axle case #11
for as small as your tractor's ft axle capacity, you could always use full syn 75/90 hypoid gear oil. Mobile & Vavoline have good ones.... now for your tranny & hyd, if it's hst, i'd stay w/K udt2 or above above, etc.
the syn 75/90 for ft axle will give you added benefit esp @ your location over conventional 80/90, & ensure the axle vent is working...regards
   / Kubota UDT or gear lube for front axle case #12
I use GL5 gear oil in both my M's front axles, always have and it gets cold here and it's a non issue. I use it because it absorbs the shock load better than the thinner UDT or SUDT.
Yes I have 3 QTs of Valvonline synth 75-90 already on hand so just need to source an additional gallon of it to do the service.
It gets really cold here but I use my trucks with 75-90/140 in them more in the cold Without issue. So I think it should be fine.
   / Kubota UDT or gear lube for front axle case #15
sounds you're on top of it, that's what i'd use.
   / Kubota UDT or gear lube for front axle case #16
I lost 4wd front wheel bearings using fluids rather than gear oil on a new tractor doing heavy work. Installed gear oil and haven't looked back.
The brand of tractor having the problem recommended fluid at the time of mfgr.....2007. In 2016 I bought another, smaller tractor of the same brand and gear oil was in the Operators Manual AND MOLDED INTO THE FRONT AXLE FILL PLUG was 90w......questions??????
   / Kubota UDT or gear lube for front axle case #17
I'm going with synthetic gear oil in mine, and I'm in a colder region.
Also, 3 quarts sounds low to me? Mine's almost 2 gallons.
   / Kubota UDT or gear lube for front axle case #20
I use Mobile 1 75/90 syn in my front axle on my L3540HSTC and my B7100DT. I use SUDT2 in both transmissions.
ZETOR 4340 TRACTOR (A57192)
ZETOR 4340 TRACTOR...
2003 Pierce Spartan Pumper Fire Truck (A54814)
2003 Pierce...
Unused SDJ-4000 9,000lb Two Post Auto Lift (A55851)
Unused SDJ-4000...
2842 (A54757)
2842 (A54757)
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A55852)
Pallet of...
