Gas for chainsaw...
/ Gas for chainsaw... #41
Yup, Seafoam and Stabil in all the gasoline, and Optilube Summer+ in the diesel. ULSD just doesn't have enough lubrication for older diesel engines. I can, and have walked up to gasoline engines that I haven't used for three years and had them startup no issues.
I buy Chevron and Shell gasoline only.
I also switched to metal fuel cans to limit moisture absorption into the fuel which helps reduce oxidation and acid formation in gas, and algae growth in diesel.
All the best,
Peter
/ Gas for chainsaw... #42
I've never heard of Optilube. I run a 100:1 2-cycle mix in my diesel. Moisture absorption is caused by a bad lid seal.
/ Gas for chainsaw... #43
The reason for ethanol in gasoline
Actually, the REAL reason for corn alcohol in gasoline is to support the corn lobby and not much else and it's a proven fact, many times over that it takes more energy to distill a gallon of corn alcohol than the gallon produces in energy.
Without government subsidities no corn alcohol distillers would stay in business.
Get your facts straight...
Do keep in mind I am a farmer but I don't grow e-corn and never will.
/ Gas for chainsaw... #44
You might want to look into the Optilube XPD and Summer+ products. They appear to have exceptional lubricity. E.g.
I don't use the XPD version because of the cost; I use the summer+ version at a slightly higher addition rate, and use SeaFoam to pick up the detergent aspects of XPD. Reading the Optilube Summer+ MSDS label, it would seem to have a significant biodiesel component (known for good lubricity).YMMV.
All the best,
Peter
/ Gas for chainsaw... #45
Interesting Peter. Never had a lubricity issue with either of my Kubota's and remember, one has over 6000 hours on it and the other 4000 hours, mostly farming so they get used hard. Same with my 97 diesel pickup truck, never had an injection pump issue or injector issue with any of them. All any of them get is a dose of biocide, nothing more and the last time the 6000 hour tractor was in the shop for a tune up and valve adjustment, the tech pulled the injectors and the spray pattern was just fine. I don't add anything except the biocide. Never had issue one.
I consider most of those additives as just expensive snake oil. I do use Power Service winter additive in the tractors to aid in cold starts, it gets cold here in the winter. Neither get plugged in and no battery tenders either as there is no electricity in the big barn anyway. I do use Nano Borate in the lube oil which is a cleaner that keeps formations under control but that is it.
Your mileage may be different but I know what mine is.
/ Gas for chainsaw... #46
My experience..
SeaFoam works ....
for some things.
I put anti-coagulant in the fuel for the tractor all winter, Just in case.
/ Gas for chainsaw... #48
Any particular reason? Neither of those are sold locally, but I haven't noticed any difference between what brands are available.
Neither have I Corn gas is corn gas, no matter who retails it. Do keep in mind that with the new Federal mandate that corn gas can be 10% or 15% corn alcohol, the 15% can be death on air cooled small engines.
/ Gas for chainsaw... #49
My experience..
SeaFoam works ....
for some things.
Does for me as well (Seafoam), at least in my GDI Ford engine. Keeps the carbon buildup in the dry intake under control and the catalytic convertor working fine. Every oil change I 'inject' 8 ounces of Seafoam into the intake tract with a warm engine, between the MAF sensor and the throttle body, shut it off, let it sit for an hour and fire it back up and blow the crap out (lots of whitish smoke). been doing that for at least the last 100K miles, every 5K miles. All I use it for actually. Like I said, diesels get biocide and Powerservice winter blend. Been down the algae road and it's not a cheap date, by a long shot.
/ Gas for chainsaw... #50
Yes, the amount of detergents and additives in the gasoline relative other brands. Could you add your own back in? Sure.
At some level, I think that if you don't notice an issue, I wouldn't sweat it. I had a low quality gas experience with my first car (1 tank full!), that triggered new plugs and new fuel filter($$). The week prior, I had just done a tune up and replaced the plugs which were ok, but it was time. A tank of bad gas later, I was convinced that I had missed something badly in the tune up. When I checked, the plugs were black and covered in gunk. Could it have been something besides the cheap gas? Sure. Could somebody have poured something like sugar in my tank? Sure, but I don't know of anyone who would have wanted to. Since that experience, I haven't worried about difference in premium pricing for "top tier" gas, since I now know firsthand the downside cost. I do try to follow gasoline research to try to stay abreast of the field.
YMMV! My "system" works for my equipment in my climate.
All the best,
Peter
/ Gas for chainsaw... #51
Do those kinds of things still happen?
I had an experience similar to yours back in the mid-70s. Happened on a cross-country road trip, got a tank of bad gas somewhere along the way, barely made it home the car was running so badly. Fuel filter was full of gunk, as was the carburetor. Even after replacing the filter & rebuilding the carb there were still driveability issues (most notably mild surging at certain speeds). Turns out the pre-filter in the tank was also gunked up. Once I cleaned that, all was well.
Never had anything similar happen since.
/ Gas for chainsaw... #52
There is a motorist axiom that goes,
"never buy gas at a filling station that has a delivery truck parked over the in ground tank access ports"
/ Gas for chainsaw... #53
Admittedly, my story is that vintage, though I did have some bad fuel episodes in the eighties. Mostly, I learned my lesson. I also think that more recent pollution vapor control measures also help keep moisture out of storage tanks, limiting corrosion and microbial growth.
I hadn't heard the delivery truck axiom. I have been told to buy fuel at stations with high sales volumes, and never to pump fuel if there is a fuel delivery happening as the delivery stirs up the tank and any sediment therein.
All the best,
Peter
/ Gas for chainsaw... #54
Doesn't 91 octane have more ethanol than 87 cause it's used as an octane booster? I use whatever non ethanol fuel is available for my infrequently used carbureted two strokes.
It depends. Where I live, the answer is no, premium has no more ethanol than regular and actually may have less ethanol in it. The state mandates 10% ethanol in all gas under 91 octane and anything 91+ octane can have anywhere between no ethanol and 10% ethanol. In practice premium here is either 10% ethanol, or no ethanol and sold at a big premium.
I always thought ethanol was added to gas to help with pricing/shortages of oil and our (at one time?) immense ability to produce corn. Or perhaps to help subsidize the corn farmers?
I didn't know it was used or able to raise any octane levels??
Probably showing my ignorance in all of the above.
Ethanol has a very high octane rating. Adding it at low concentrations is like mixing in 115 octane fuel, adding 10% to regular gas increases the octane by 2.5 points. Adding it in higher concentrations depends on the engine it's run in. E85 is roughly 105 octane in a naturally aspirated engine, about 115 octane in a forced aspiration and aftercooled engine, and 130+ octane in a forced-aspiration non-aftercooled engine. Ethanol takes a bunch of heat to vaporize which significantly lowers charge air temps, which is a big component of power production in forced-aspiration setups.
Ethanol was initially introduced to reduce MTBE as an oxygenate to reduce emissions due to the previously-mentioned groundwater contamination with MTBE. The discussion regarding corn subsidies came a bit after that. The fact that it raised octane levels did not appear to be a factor initially as the initial ethanol blend here was 89 octane mid-grade and that was it. This was regular 87 octane with a little under 10% ethanol added. If it was about raising octane they would have added ethanol to all grades right off the bat and you would have seen them add ethanol to 92-93 octane premium to make 94-95 octane super-premium. E85's very high octane rating would have also been widely publicized, instead I have seen an octane rating on exactly one E85 pump ever. Now that we very well know ethanol raises octane, it still isn't a factor. It seems any time there is discussion outside of the racing community (where it has some big fans) about actually using ethanol to boost octane and moving beyond the 1970s post-leaded-gas malaise-era 87 octane standard, you get all of the "it screwed up my chainsaw I hadn't used for four years" or "you are just making evil Monsanto rich", "you are starving kids in Zimbabwe," and the other usual responses. And now we are stuck with DI setups and their significant drawbacks in gasoline engines in order to try to work around running a heavily-turbocharged engine with double-digit compression ratios on the same swill that barely ran engines with maybe an 8:1 compression ratio in the '70s.
/ Gas for chainsaw... #55
Coincidentally, I'm watching an Engine Power show where they built a small block chevy and ran it on gas, then ran it on E85. It makes about 25% more power on E85.
/ Gas for chainsaw... #57
/ Gas for chainsaw... #59
Switching to Diesel chainsaw will solve all these gasoline problems some of you are having.....:ROFLMAO: :eek:
2007 International 4300 S/A Dump Truck (A64556)
2007 International...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
2014 Freightliner M2 106 Bucket Truck, VIN # 1FVACXDT4EHFV0598 (A65563)
2014 Freightliner...
2014 Caterpillar CB54B Articulated Vibratory Tandem Smooth Drum Roller (A64553)
2014 Caterpillar...
John Deere 4020 Tractor w/ Loader (A66285)
John Deere 4020...
