New (used) IH 7500 Dump Truck purchase, modification & fix up
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #241
They claim 1/4”, but I need to talk to the guys there on the ground, not the sales lady.
A new 12’ Beau Roc body installed is like 18-20K even with me doing part of the work. This is what I really want, but just don’t have the jingle for it….too many other repairs & projects going on. Trying to find a used 12 footer IS a needle in a hay stack. The 7500 may be too old to “justify” a new dump body anyway.
I think we are down to the Air Flo in New York or the black 12’ in S. Dakota from Van Der Haags.
I like the Air Flo because it’s AR450 steel, new old stock (never used) and probably a little cheaper since I can go up and get it, BUT I have to buy a hoist for it.
I like the black body because it’s not a salt body-nothing to modify, just put it on. Looks straight & clean. However, I don’t know how heavy duty it is. Seller claims 1/4” steel, but I’d bet 3/16”. Just don’t know.
I plan on being pretty rough on this. Rocks, stumps, etc. but I am pretty careful.
Maybe 1/4 floor and 3/16 sides etc.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #242
The black one looks a bit more beat up than I initially thought, not bad just more.
Bottom looks quite beat up and bowed between the bunks, can't see it being 1/4" plate. Diagonal braces from the frame out are nice, saves the bottom from sagging when things start to get old. She's really dry tho but doesn't appear to be corroded to the point of failure if it's looked after.
So they want $3,500 for this one plus how much to ship and other than mounting (and a good spray of oil or undercoating) the total cost for this one would be???
Compared to the initial cost of the new salt body and modifications, needed install parts plus shipping?
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #243
Here’s the listing. I still don’t see a tailgate release handle. I don’t see any linkage for one in the pictures underneath. There is a cable of some kind in one picture.
This looks like linkage to me (right side of picture by the mudflap):
Aaron Z
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #245
For your hay hauling pleasure. All wheel drive and automatic transmission.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #246
Most newer dump bodies have the air tailgate and the cable runs to the hyd valve on the pump to stop the body at full lift (pulls the valve to neutral) .
Kinda like that. Takes away the guilt of being the first one to put a dent in it. 😧 😂
They haven’t gotten back to me on a cost estimate for shipping. I’m guessing $1,500 if I’m willing to wait for a shared load. So probably $5,000.
The Air Flo is $4,500 + $1,500 for hoist. How much to fab up a cover for the floor & tailgate I’d guess another $1,000. Then it needs blasted & painted. Probably another $1,500 +/-, so the Air Flo body is probably $9,000 total. That’s also with me losing a day in trucking to go get it. At that point, I might as well get a new dump bed.
The black body’s paint aint great, but it sort of matches the condition of the truck, so I wouldn’t need to paint it immediately. Was thinking I could lay another sheet of steel in the floor if I want to dump boulders in it. Probably be ok as-s.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #248
Was thinking I could lay another sheet of steel in the floor....
That is a pia to do not to mention trapping moisture between the two. If you don't plan on removing the existing, (and I don't blame you if you don't) leave it.
....so I wouldn’t need to paint it immediately.
True, but something I would do immediately after getting it mounted is spray the crap outa the underside.
Well, they want $2500 to ship the dump body. Sheesh.
Holy crap thats crazy. I asked for a split load price and that seems more like a dedicated load price.
So that takes the price just for body & shipping to over 6K.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #250
Ouch, that's sure as he** not cheap. Does it make you think more about going yourself to get it?
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
Ford 8510 (A53317)
Ford 8510 (A53317)
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
Bobcat A770 (A60462)
Here are some similar links:
