NH634 bale density.
/ NH634 bale density. #1
Southernspeed
Gold Member
Central Virginia
Massey Furgeson 2850M
Is there a way to adjust the bale density on a 634? The bales were 'ok' but could do with being tighter. And how much would the type/condition of the grass affect it?
/ NH634 bale density. #2
Not familiar with that bailer but as a rule, speed over ground (how fast or slow the pickup eats the hay) will determine the density of the bale. The faster you go the less dense the bale will be. The slower you go the more dense it will be.
/ NH634 bale density. #3
I have a 630. Make sure your tension springs are within spec, but my experience is driving slower makes a better bale. I bale about 4 MPH.
/ NH634 bale density. #4
One reason why I bought a new Kubota bailer is bale density is all hydraulically controlled as in no tension springs.
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
TROY-BILT GENERATOR (A64553)
TROY-BILT...
Lot 602 (A62613)
Lot 602 (A62613)
213088 (A64276)
213088 (A64276)
E-Z TRAIL HEADER CART (A64278)
E-Z TRAIL HEADER...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
