L4400 no Start
/ L4400 no Start #21
Tried jumping starter nothing at all, so I guess guy who said it was ok was wrong, finally got switch out that was a 2hr ordeal, that one center bolt that holds the cowl on top there is just no way of getting to it with taking a die grinder and cutting away the metal on the hood, have checked all fuses still getting no power to dash so thats why i figure it has to be the switch so got one ordered hopefully that will be in tomarrow ,,, but pulling that starter off i just dredge doing that if that loader wasnt on then i bet it take 3 minutes to pull off.
Do you mean you jumpered the solenoid trigger line (small wire) to 12v? Unless the solenoid gets triggered the starter motor is not going to do anything.
/ L4400 no Start
i turned the ignition on then took a jumper wire placed on the small tab under the starter motor then applied it to the battery, now this worked a few times to start the engine but tried the other day and nothing happens, no dash lights come on when turning the key so not sure what happend but I thought if main power was going to the starter all one had to due to was add power to the solinod to get it turn over
/ L4400 no Start
Alright Fedex drove up dropped off my new switch at first was disappointed due to the harness was way to short, but just take the old one off and swap, took about 10 minutes, plug it in turn the key and the dash lights up ok things looking good, double check everything to make sure i havnt left a wrench or something that might get caugt, turn the key to start nothing crap, ok double check seat switch, pto switch shuttle shift switch all good, ok well went to jump start it and it fired up so not going to bang my head anymore on chasing down why i cant key start it just going to wire up a push button switch and be donw with it. Considering i was going to have to spend another 3k to get it fix at the dealer im really happy
/ L4400 no Start #24
The L4400 has inadequate wiring that connects the battery to the starter motor. The battery terminals are thin and inadequate small terminals connect the 50 amp fuses.
After several years these sections with be clogged up with dust or even have some corrosion, you need to disassemble that area and file the metal connectors with round/flat files, sandpaper or a wire brush.
The area that the chassis is grounded to doesn't give a good indication that it connects to the rear of the chassis properly, mine was attached but separated by painted sections of metal plates. You may need to reground a better section of chassis.
You may even want to completely change the battery terminals with proper ones. Oli express and abay also have resettable 50 amp fuses, they are worth using instead, because if you blow a fuse, its likely the Kubota shop won't have a spare 50A fuse in stock anyway.
But for me even after cleaning this area, the 12 volts that connected to the key switch still had dropped down to 9 volts after, which indicated the key switch was corroded and was unable to pass a current properly.
You may be able to start the L4400, but have the starter motor fail on you where it stops and starts making a clicking sound instead. This may fool you into thinking the battery needed replacing.
Or the L4400 wont start at all, and the only way you can get the start motor running is by connecting a lead from the 12V positive battery to the terminal section of the starter motor. This is a dangerous thing to do if the tractor is in drive, but as long as you keep the footbrake on, the lever in neutral, you should use long lengths of jumper cable to distance yourself from the movement of the tractor also.
The starter motor has two electrical connections - one with a large ring connector that goes directly to the battery, unswitched, using a 120 - 170A cable. The other smaller connector is a spade terminal that goes to the ignition key switch via a thin cable in the loom.
From observation the spade terminal that activates the starter motor is using way more amps than it should. It shouldn't be using more than 8 amps. To fix things properly (to keep the safety mechanisms intact) you should order a new key switch mechanism and replace the oem relay that it connects to. If those 2 weren't the problem, rat chewed cables are common problems also.
I fixed mine by connecting the starter motor output to a 12v auto relay that is positioned near the battery and connects a 12v through a thicker wire to the spade terminal of the starter motor. The safety mechanisms still worked also.
There shouldn't be any significant corrosion between connectors, but if there is, its often from connecting dissimilar types of metal.
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63118)
2012 Ford F-150...
2024 JCB 35Z (A60462)
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
429782 (A61165)
429782 (A61165)
