BV4160
/ BV4160 #1
NHJohn
Virginia
New Holland T4.75
My BV4160 baler is set to form a bale 59.7 inches but the bale comes out 54 inches, any solutions?
/ BV4160 #2
Sounds as if bale size sensor needs to be adjusted. That would be just fine if your baler belonged to the man where I inspected some hay he had for sale last year that was advertised as 4X5. When I looked at bales there were significantly several inches less than 60''. I quizzed the owner of the hay & he stated well that's what my baler's monitor showed 60''. To which I stated I guess you don't own a tape measure??
/ BV4160 #3
There is a bale size correction setting. I don’t have the book in front of me, but the icon on the monitor looks like a bale w/ a small line on the top.
/ BV4160
Thanks, I called the dealer where it was purchased, I'm not the original owner and they were of no help. I bumped it up to 60.8 and it is now 56"
/ BV4160
I will have to look at the book regarding that. I keep it in the tractor in case I have an issue in the field. I bumped it up to 60.8 and it gives me a 56" bale.
500BBL WHEELED...
International S1900 (A61307)
International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
2014 Jeep Grand Cherokee SUV (A61569)
2014 Jeep Grand...
