Poulan Troubleshooting
/ Poulan Troubleshooting #1
KennyG
Super Member
SW Michigan
John Deere 2320
I've run out of things to try on my Poulan Pro 20" (actually a Husqvarna). It wouldn't start and had no spark. I checked the plug, and it sparked on another saw. I disconnected the kill switch, no change. I got a new coil (with plug wire) and still no spark. I rechecked the gap and the plug. Still nothing. This is a pretty simple system. Is there anything else to try before I throw it away?
/ Poulan Troubleshooting #2
I've had a few Poulans, they are disposable. I'd upgrade, I wish I had years ago, but was lured to the Poulan due to the price.
I have 3 Echo's, all great saws, all are 10+ years old and start and run like new.
The Poulan is a backup to my newer Stihl. I would like to keep it running though.
/ Poulan Troubleshooting #4
Are you only checking for spark using a spark plug...??
If so...try using your hand/fingers...hold the wire and ground the base of your hand to the engine...slowly turn the crank at first...
/ Poulan Troubleshooting #5
Yep. I have a Poulan Pro 18" that I've had for about 15 years. I cut about 6 cords a year with it. $119 factory reconditioned. Only problem I ever had with it was a crack in the coil that would open up when the saw got hot. Replacement was about $40. The only reason I fixed it was because I wanted to prove to myself that I could. ;)
I have a different saw now, but keep the Poulan for small stuff and a backup.
/ Poulan Troubleshooting #6
Did you check the air gap on the coil, besides the gap on the spark plug?
Yes, I set it about 0.010. I couldn't find the exact specs but I think that's about right for most small engines.
I would like to get it going again. I've got an old 14" Poulan that's about 25 years old and it just keeps going.
/ Poulan Troubleshooting #8
To you, you have checked everything: spark plug, ignition coil. But to me you have not checked everything. Try few more things:
  • Check if the air filter is clogged. Clean it.
  • Gas to oil ratio might be inappropiate
  • Fuel might be bad
/ Poulan Troubleshooting #9
I know this is not helpful but the old green / grey / purple green 1990's poulans were just ok to keep and fix as spares. If you have the newer yellow, or black yellow, please just toss it. They are very difficult to keep them running right. This is due to a very poor crankcase design that not only develops air leaks, but in some cases does not hold the bearings tight enough as a result or warping and / or bad machining. Not to mention the end of the crankshaft can snap clean off for no reason.
The same issues occur on the Husky 120 models, but the crank shaft is better design.
/ Poulan Troubleshooting #10
I own a Pullin’ and Pullin’ and Pullin’. Wish I didn’t, but I only use it once a year or so.
/ Poulan Troubleshooting #11
I cann't confirm the 0.010 gap but have always just used the thickness of a paper matchbook cover or a good business card.
Seemed to always work for me. Probably close but not exact thats for sure.
You got me thinking though next trip out to the shop I am going to check if match cover is close to your 0.010 number
cheers
/ Poulan Troubleshooting #12
It has a magneto to make spark?? Try a wire brush or sandpaper
to make the metal nice and shinny! I have seen many a small engine
that the mag got rust and no spark!
willy
/ Poulan Troubleshooting #13
willy
The rust doesn't effect the magnet to make spark. The rust will cause the air gap to get smaller to the point it rubs the coil, and that will effect spark. So minor rust coating is no big deal but crusty buildup will.
/ Poulan Troubleshooting #14
I crack up when the stihl guys come in talking about poulan and pulling them to start. Yet their complaints are I cant get my stihl started and takes 12 pulls to even fire off.
I walk over to one of my poulans and sometimes start and pop on first pull. Which amazes me if I am quick enough to push choke in to catch it to keep it running.
IMHO it comes down to the owners and saw maintenance.
No matter the brand all saws I own are same way. Easy to start.
Be it stihl, husky, echo, dolmar, poulan, jonsered, partner and even the china clones.
/ Poulan Troubleshooting #15
cheers
.010” is too small of gap. The matchbook cover described would be between.020.-.040” open the gap and spark should be present. In the past I have used neon bulb to verify spark strength over shocking my self. You can use voltmeter on high dc voltage setting at least that would help with strength of spark. Mind you negative leads both bulb and or meter to known ground. I have 3 Poulan saws only use synthetic fuel in them to assure stability.
/ Poulan Troubleshooting #16
I bought one of those lightweight plastic Poulan ones many years ago when they first came out. My neighbor got one first and I really liked how light it was. The interesting part is both saws failed after about the same amount of operating time and the same failure mode. One of the screws on the flywheel vibrated loose and ended up getting wedged between the flywheel, fuel tank and chassis putting holes in the plastic.
Last cheapo saw I ever bought.
/ Poulan Troubleshooting #17
FYI speaking of gap on magneto not gap on spark plug
Ford N Series Tractor (A66285)
Ford N Series...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2006 Kenworth W900 Day Cab Truck, VIN # 1XKWDB9X76J112716 (A65563)
2006 Kenworth W900...
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
CATERPILLAR D6N LGP HI-TRACK CRAWLER DOZER (A65053)
CATERPILLAR D6N...
2016 Caterpillar 304E2 (A64126)
2016 Caterpillar...
