Z330R zero turn mower
/ Z330R zero turn mower #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
kicking around the idea of buying one. Any one have a comment about them? The price is up to $4200 now with a 48" deck.
/ Z330R zero turn mower #2
Are you sure about the model number? JD doesn't list a X330 "R". You mention the price is "up to $4200", are you bidding on a used machine? A new X330 with 48-inch deck lists for $4399.
/ Z330R zero turn mower #4
how much grass do you plan to cut ?
/ Z330R zero turn mower #5
It appears that this mower can either have a 24hp Briggs or a 23 HP Kawasaki engine, which may account for price differences. I personally think Kawasaki engines are worth the premium.
/ Z330R zero turn mower #6
The Briggs on my Z225 made it to about 220 hours and got to be such a pain that I replaced it with a different engine made for Husqvarna.
I am planning to just do the trimming with it on about a 3 acre yard. I have a RFM behind my 3039R & cab for the rest of it.
/ Z330R zero turn mower #8
I have been told by several folks that the quality JD products sold at Home Depot is less than at a JD dealer. Don’t know if that is true or not.
I'm guessing the people that assemble them at Home Depot may not be as reliable as a Deere trained mechanic at a dealership, so you may be correct.
/ Z330R zero turn mower #10
I've got the Z355E with the 48" deck and have had it for just over a year now. I probably mow 2.5 acres around the house, driveway and front 'horse exercise' area. It's worked flawlessly, although I do have to keep my mouth shut, due to rough ground. :) It's a non-commercial so there's not a lot of seat suspension.
I did purchase mine from my JD Dealership. When they delivered it, one of the front caster wheels had lost the bead = they immediately replaced/repaired it.
It's a LOT of fun (and quick) once you get the hang of steering it.
Oh, and I also purchased the optional towing package/bumper... 'cause you never know when you might need it.
Here is an update;
I talked myself out of the Z355R and bought a Z545R.
I took it for a test spin down the driveway and decided I need to practice before I start trimming around anything expensive.
/ Z330R zero turn mower #12
Good stuff and congratulations.
When my Z-trac was delivered, the Dealership bloke recommended that I practice driving it around the property without the mower engaged & the deck up until I got the 'hang of it'. I found that if you kept the left control at a steady 'speed' and used the right control to 'steer' was best... just don't 'get cocky'. :D
What size deck did you get?
/ Z330R zero turn mower #13
Wagtail
Good point, but in the States we drive on the right so we would hold the right control steady and use the left to "steer". :D :D :D ;);)
I got the 60" deck.
Okay, my first findings. When things get exciting, my feet do nothing about crash avoidance. And, when I let loose of the handlebars, it keeps moving...neutral is hard to find in the second before a crash.
My yard needs mowed for the weekend but I think I'd better mow the driveway for a few hours first.
Craftsman 16in Variable Speed Scroll Saw (A64553)
Craftsman 16in...
2022 JCB 509-42F TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42F...
227 (A64278)
227 (A64278)
2023 Chevrolet Silverado 5500HD Auto Crane 6006EH 6,000lb. Crane Mechanics Truck (A64194)
2023 Chevrolet...
VICON ROTOFLOW SPREADER (A63291)
VICON ROTOFLOW...
2007 Ford F-150 Pickup Truck (A64556)
2007 Ford F-150...
