Good morning!!!!
   / Good morning!!!! #169,781
We hit 82° today.
Ran out and got general tso for supper.
Then I fixed the BH dolly with some timber locs lags. Let’s see if they hold, BH is on the dolly now.
Mixed and sprayed 2 gal of weed juice, mixed 2 gal more.
Son mowed front and back to the field.
Neighbor mowing, farmer planting across the road. Big case with a loud hydro whine. He stopped and did a regen.lilac blooms are gone, locust tree blooms about gone.
Saw my first hummingbird today.
Maybe tomorrow I’ll get blades sharpened.
   / Good morning!!!! #169,782
Unlikely to see one here in Oz but 12 HP doesn't sound a lot even for a 39" cut. Probably possible to fit a bigger donkey in it if needed.
My old wheelhouse is 12 hp. That was big engine 35-40 years ago. It might have 36” deck, I forget. I need to get it running again. A couple years later they became Toro.
   / Good morning!!!! #169,787
70F clear sky high temp of 78F.
Work day was burr I was hoping 2 cords of wood were waiting for me...not to be. :(
Woke up trimmer from it's long winter nap and took it for an hour walk,sfterwards woke up 1 of rider mowers from hibernation,gave it new filters fluids and blades and went for ride,afterwards mower got bubble bath.
Very soon heading for the deck to enjoy smooth cigar wait for critters and stars.
Enjoy your evening all.
   / Good morning!!!! #169,788
Day went by pretty quick. Appointment done and over with. By the time I got home, the wind was still ripping, so made philly cheesesteaks and fries for dinner.
16:00 and wind still going strong..... wifey said forget going outside.... who am I to argue? Local weather reporting wind should diminish after 20:00.....
The new weather forecast is predicting good chances of rain for the entirety of next week. The best chances for Sun / Mon.
Just going to relax this evening..... I have misplaced my energy again..... it's probably somewhere under the bed.... the last two nights of trying to sleep resulted in a bunch of tossing and turning..... it must have fallen out during one of the flops.....
Picked up a large "postcard" in the mail today, from LS tractor. Apparently my tractor dealer, RCO Tractor down outside of Austin is no more...... "due to sudden unexpected circumstances". Wow, they even opened a second location up in Greenville a couple years ago. I'm going to have to make some calls and find out what happened.
It's one of the few places that I would trust a deal made on a handshake. I hope nothing happened to the owner... family run.
   / Good morning!!!! #169,789
Good (Friday) morning. Overnight Low of 5.4C and it's presently 15.5C, a high overcast sky with light variable wind. The 'Guessers' are covering their arse with the chance of a shower. :rolleyes:
As I mentioned yesterday, I'll be transferring the horses into Paddock #5 (water trough shift & a new round of hay). Which probably means that tomorrow will be cleaning up Paddock #4 (chain-harrow & z-turn mulch).
I do need to give myself a hair cut and clean up my scraggly beard... rogue hairs are going everywhere.
   / Good morning!!!! #169,791
I picked up 2 66 lb bags of stone mix cement today for $6.48/bag.
Didn't get anything done with the tin work. Twas 77°F when I went to town, I don't do so good after 70°. 2 summers ago I got tangled up with a touch of heat stroke, now I insist on A/C in the truck and car. None in the house, but I can turn on the furnace fan and ge the cooler air upstairs.
Tomorrow I am going outside and do the tin work in the early A.M.
High for tomorrow is supposed to be 75.
   / Good morning!!!! #169,792
63F and "Fair" @ 22:00, heading down to around 52F for the low tonight.
High here today hit 87.4F ... :oops:
Filled hopper feeder first thing, also scattered cracked corn for the ground feeders. The two suet cakes I put out the other day are already gone.
Then got small items unloaded from the van into the dump cart on the Cub. Moved some of those up to the front, got a couple boxes of cat litter moved into the house, removed labels from some of the peony supports and took those around back and dropped them off.
Loaded up the weeds The Woman had pulled in the garden + the weeds from the flower bed into the dump cart and hauled those up to the compost pile:
Rhubarb looking good:
Probably should fertilize it though.
After I got back from that I dropped the bucket off the Kubota and put on the pallet forks and headed up to the shop to grab an extra pallet.
Headed over to the van and unloaded almost half of the 30 bags of mulch onto the new pallet and parked it over on the west side.
Went back and pulled the original pallet out with the pallet puller and chain and parked that next to the first one I took off.
After that I moved the van up to the garage, backing it in ... so the rear wheels would be in the shadows cast by the garage.
Woman was working on plants some new plants in pots while I worked on the brakes.
Got first wheel and caliper off, looked the new pads Autozone gave me and they were wrong.
So made a trip back in there and got that sorted out. They didn't have the correct ones, will be in tomorrow.
Came back and had some of the stuffed peppers The Woman made
Then got the other wheel and caliper pulled.
Came back in and had another stuffed pepper ... and now I'm stuffed.
But ... She also made chocolate pudding so ... :giggle:
Hope everyone had a great Thursday ... (y)
   / Good morning!!!! #169,793
Time spent, but….
Not happy with first flail fix attempt so had to undo everything. Was actually looking pretty good, so much so that I hit the threads with blue loctite and tightened. Got it almost mounted on tractor when decided I didn’t like the geometry and unmounted. Of course having used the loctite I had to immediately disassemble before it completely set up. Didn’t take any pics .
Next attempt is quite similar but the lift pins will point inward rather than outward. Oh well.
   / Good morning!!!! #169,796
Good evening all. 64ºF for the start, overcast, light breeze. Light to moderate wind, overcast thinned in afternoon, no rain fell even though it was forecast, high temp was 85ºF HI 91ºF. Bike ride to start morning, got call on motor, no direct replacement available :( will borrow a push mower to get inside fence. I will tear down the old engine and see what it will take to repair. Nap in the afternoon.
Dennis the funniest thing was the expression as she looked around as if she is wondering if she was caught.
Ron glad you were able to start the weed spraying. Good to hear grass mowed. and bricks loaded. Hope wind was down today. nice pic
Drew glad you are enjoying your coffee. Hope zoom meeting went well. Sorry about needing to net the strawberries.
Billy hope you had good time in the hills.
Buppies glad you slept well. prayers sent.
Kilroy glad you don't have to learn the hard way:)
Frits glad trip to Messick went well. Good luck getting all service done and not hurting shoulder. I trust you will be there when daughter asks for help.
Kilroy good find
RNG glad new stucco crew worked well if overly salty. Bet it was fun watching barn swallows. Sorry about the tire woes, hope bead wire came off ok without too much salt required. Good luck getting VW started.
Ken sorry no salt after all that effort. nice pics
Bill glad you got back to sleep. Hope town/dump run successful.
Drew sorry back is not happy. Good to hear borax working.
Ted hope winds die down. Glad drip irrigation installed.Interesting about the fuel stabilizer, Have been using Stabil marine stabilizer for years with no fuel problems. Hope appoint went well and you were able to get more done
RS hope brake project went well. Good luck with coon.
David hope flail finished and cutting well. Sorry about Flipper needing diags. Hope you and gate got thumbs up from Sophie.
Scaredy interesting mower. prayers sent.
Dennis glad you have dolly 1.0 done. yummy sandwich. Sorry you already dolly 1.1.
Billy thanks for pics.
Kilroy nice job on spare carrier. nice pics as well.
David thanks for link.
Jay glad nice drive to get replacement microwave.
Dennis hope the timberlock lags hold. Sounds like a lot of progress going on.
Jay interesting though on Dennis's sandwich.
Thomas glad good work day, sorry about no new wood.
Ted glad you have rain in forecast again. We had 3+ inch in forecast for this week, likely will get less than 1/2 inch. Hope sleep will go better tonight. Sorry about dealer shutting doors not many places like that left.
Randy(wag) hope horse transfer and paddock cleanup both went well.
Bill sorry about tin work. Hope you get started early tomorrow.
RS nice pile of weeds. Sorry about the incorrect brake pads.
David sorry about not liking the first flair repair. Hope round 2 goes better.
prayer for all, especially Jay/Peg, Kyle /Daughter, /mom's breathing, /learning new job, /friends upcoming new baby, /son's migraines, Bird /aging issues, Ron /heart, Billy /mom hypertension & congestive heart failure, David(moss) /remodel, /divorce, Buppies /new skin cancer spot and treatment, /back surgery healing, /wife knee healing, Thomas /gout, Phil /reflux, Frits /veteran son with mental issues, /granddaughter with Evans Syndrome, Ken /dad possible dementia, Steppenwolfe /son-auto immune disorder, Grev /wife's eye, Ted /knee recovery, /retirement & disability red tape, /family issues, Lou /eye issues, /loss of brother, /heart issues, Doug and wife/health issues, / hand nerve and surgery, /fall and recovery, / wife headaches and heart eval, / David(sadamo)/Sophie's and David's new eye surgery recovery, Chris /neighbor's granddaughter and Covid issues, Scaredy/shoulder dislocation, /marriage dissolving, / friend stop drinking, Paul/ wife's healing from back surgery, Dennis /retirement, /neighbor issues, /land development, /favorable winds not in the forecast there "alligallyitus" and back in hospital, Drew /foot heel issues, /friend's wife cancer diagnosis and recovery, mike /wife's healing from surgery, Scotty /back pain, Helogabals /second opinion, /wife's friend situation, Fatjay /father broken hip, Ukraine war, and Country.
   / Good morning!!!! #169,797
Drinking great tasting cup of coffee. 47° with clear skies this morning. Heading to 79° with slight chance of rain in evening. Grocery shopping went well. No weed killer got put down yesterday. Went to pickup my pressure washer at neighbors. Their mower would not start. Battery was bad. Quick trip to Walmart and installed. Choke was not working properly. Lubed, to get it working. Third pull and cable broke. Ordered new one. With that fixed I headed back home. Decided my old Craftsman SS sprayed needed repair. Replaced seal for pump to tank. Pickup line inside tank was not sealing properly. Replaced pickup tube. Now sprays like new. Will see about spraying more weed killer today. Need to do a diesel and Rec Gas refill today. Diesel is down to $3.95. While out will stop by new Kubota dealer that is near gas station. Never know what will be found there. Then back to weed killer
Duck Dunking.
Everyone stay safe and well.
Good Morning All.
   / Good morning!!!! #169,798
Canadiana still makes is a push mower and a snow thrower.
if you scroll down, no "about us", but clearly a product under Briggs & Stratton umbrella.
Ron, you were a regular Mr Fix It!
86 degrees today, will feel like summer
RS, you get an incredible amount of work done every day
am still waiting for first sawdust from Unisaw
you are going to get it dirty aren't you?... ;)
my day is consumed by a mid day trip over to Pemberton NJ to meet a friend who is picking up a box blade from another friend.
I gave the 48 Land Pride box blade to one friend many years ago, before I left for NC, too small for my current tractor. He used it a little but still looks like
new. I saw it outside several weeks ago getting grown over by honeysuckle. He is happy to pass it along to another friend that will actually use it, my younger friend
with the almost new Kubota LX30 something. So it's musical chairs for the box blade. the box blade weighs 318 pounds, too much for two of us old guys to pick up, but
young friend bringing a dolly of sorts and he has a 12k winch on his trailer. Should be interesting. He is desperate to find some use for this deluxe small cabbed tractor, bought to do snow last winter and clearly never used, we just didn't get any snow to speak of. So almost brand new tractor sitting in garage. I'm considering donating a cheap PHD to the cause so I can use the tractor to plant trees.
hope you all have a great Friday.
   / Good morning!!!! #169,799
I only wish I could weld half as good as that…
$250 materials+labor, all I did was draw the diagrams and then paint it!
   / Good morning!!!! #169,800
Kilroy good find
The most important aspect of the spare tire carrier is that, when Little-Miss-Dubious-About-Most-Of-My-Projects saw it installed with tire mounted, the lightbulb finally went off and she enthusiastically approved 😎👍
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A60429)
(INOP) 2016...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
