Need help ordering new hydraulic couplings
/ Need help ordering new hydraulic couplings #1
seapea
Gold Member
SF Bay
Kubtoa B2620
I have a Gearmore 3 spool hydraulic control valve for a top-n-tilt kit that the Kubota dealer installed installed when I bought my B2620 in 2008. I've only ever used 2 of the 3 remotes. Now I'm getting a flail mower with hydraulic side shift, so I'll be using the 3rd remote with it. The flail mower will come with the hydraulic hoses, but not the couplings, and I need to figure out what to order. Here's a picture of what I currently have, with one of in-use remotes uncoupled:
The seller says:
"Hose ends that connect to the tractor are fitted with 1/2-14 NPTF threads, you will have to provide the corresponding fittings to complete the connection to your tractor"
It looks like I currently have 1/4" couplings. The part numbers are Pioneer 4010-2P and 4050-2P. I can find these online, although the 4010-2P looks different so I'm not so sure it is compatible. Seems they changed the design since I bought mine. Also they are 1/4", and the hoses connectors are 1/2", so I assume this means I need a 1/2" to 1/4" adapter. If that is correct, I'm having trouble locating the part.
Thanks for any help you can offer!
One other thought. If I can't find compatible couplings, couldn't I remove the quick connect plug from the valve bracket and attach it to the hose, so it can pair up with the socket still attached to the valve bracket. Then I can buy pretty much any 1/4 coupling for the hookup of the second hose.
/ Need help ordering new hydraulic couplings #4
Look like Pioneers to me 1/2 NPT.
Just need to know what the new mower comes with. You have a very common fitting there in my limited experience.
All the information you need to know might be on the slide ring/body of the female couplers....Should be manufactures name and part number... From little bit I can see the couplers look like they may be "Pioneer"...
Yes, they are Pioneer 4010-2P and 4050-2P.
The 4010-2P and 4050-2P are 1/4" according to the Pioneer catalog. See page 4:
And the new mower will come with (as quoted from the seller):
That is why I asked about converting from 1/2" to 1/4".
I pointed out the my 4010-2P looked different than pictures I see when vendors sell this item. Here's what I mean. First pic is mine:
Second pic is from a vendor:
These just don't look the same to me, but maybe it's ok.
/ Need help ordering new hydraulic couplings #8
I went to a local hydraulics store and was able to get the exact same couplers. They seem to be working well with my existing remotes. I was also able to get the 1/2" to 1/4" adapters. They aren't working so well. The leak badly on the 1/2" side where they connect to the hose. The 1/4" side that connects to the coupler is fine. I've tightened it down a lot and am afraid to go any tighter. Do I need to use tape or dope? The one thread I read on that topic just left me more confused.
The adapter is Parker part 0201-8-4. You can find it and its specs on the following catalog page:
It says it is 1/2-14 NPTF, which is what my hose also claims to be, so I assume it is the right part. Any suggestions on how to resolve the leak?
I did a bit more research. From what I've read, NPTF is designed to not need any type of sealant, whereas NPT does need a sealant (mine is NPTF). Also, reuse of NPTF connectors is not recommended due to the deformation that happens during tightening, but if reused, then a sealant is recommended.
I'm a bit unsure how to proceed. It seems I have the right parts as they are both NPTF. Is my leak due to under-tightening or over-tightening? My guess would be the latter, so maybe the only hope at this point is to redo the connection with teflon tape.
For the most part I think I have the leaking resolved. I redid the fittings using teflon tape. Initially results were pretty good, but there was a slow leak with one of the fittings, maybe a drip every 5 seconds. Still, a vast improvement over the constant flow I was seeing before. I then tightened it up a bit, and it got a lot worse. So I redid it again, this time using a bit more tape (maybe 5-6 wraps instead of 3-4), and this time didn't tighten it as much. That seems to have worked really well. There might be a very slow leak, like a drip ever few minutes. I'll keep an eye on it. If it becomes problematic in the future, I might just have the hoses redone with 1/4 fittings so I don't need the adapter. Fortunately this leaking will only be an issue for the week or so a year I'll have my flail mower out, since that's the only time these hydraulic hoses will be attached.
/ Need help ordering new hydraulic couplings #15
Unless you're careful applying it, small bits of tape can end up in the hydraulic system.
I have had good results with LocTite 545, which is made for hydraulic NPT fasteners. Clean the threads well and let it cure for a day before using it.
Yes, I was aware of this. I applied the tape a couple of threads below the tip, and also made sure I wrapped in the proper direction.
/ Need help ordering new hydraulic couplings #17
If the tape fails, you can try loctite 545 but let it set up before hitting it with pressure
2020 John Deere 6120M (A62180)
2020 John Deere...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
2010 Case 580N (A60462)
2010 Case 580N...
6' BOX BLADE, 3PT (A63290)
6' BOX BLADE, 3PT...
2025 Swict 78in. Bucket Skid Steer Attachment (A61572)
2025 Swict 78in...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
