Need help ordering new hydraulic couplings
   / Need help ordering new hydraulic couplings #1
seapea
SF Bay
Kubtoa B2620
I have a Gearmore 3 spool hydraulic control valve for a top-n-tilt kit that the Kubota dealer installed installed when I bought my B2620 in 2008. I've only ever used 2 of the 3 remotes. Now I'm getting a flail mower with hydraulic side shift, so I'll be using the 3rd remote with it. The flail mower will come with the hydraulic hoses, but not the couplings, and I need to figure out what to order. Here's a picture of what I currently have, with one of in-use remotes uncoupled:
The seller says:
"Hose ends that connect to the tractor are fitted with 1/2-14 NPTF threads, you will have to provide the corresponding fittings to complete the connection to your tractor"
It looks like I currently have 1/4" couplings. The part numbers are Pioneer 4010-2P and 4050-2P. I can find these online, although the 4010-2P looks different so I'm not so sure it is compatible. Seems they changed the design since I bought mine. Also they are 1/4", and the hoses connectors are 1/2", so I assume this means I need a 1/2" to 1/4" adapter. If that is correct, I'm having trouble locating the part.
Thanks for any help you can offer!
One other thought. If I can't find compatible couplings, couldn't I remove the quick connect plug from the valve bracket and attach it to the hose, so it can pair up with the socket still attached to the valve bracket. Then I can buy pretty much any 1/4 coupling for the hookup of the second hose.
   / Need help ordering new hydraulic couplings #4
Look like Pioneers to me 1/2 NPT.
Just need to know what the new mower comes with. You have a very common fitting there in my limited experience.
All the information you need to know might be on the slide ring/body of the female couplers....Should be manufactures name and part number... From little bit I can see the couplers look like they may be "Pioneer"...
Yes, they are Pioneer 4010-2P and 4050-2P.
The 4010-2P and 4050-2P are 1/4" according to the Pioneer catalog. See page 4:
And the new mower will come with (as quoted from the seller):
That is why I asked about converting from 1/2" to 1/4".
I pointed out the my 4010-2P looked different than pictures I see when vendors sell this item. Here's what I mean. First pic is mine:
Second pic is from a vendor:
These just don't look the same to me, but maybe it's ok.
   / Need help ordering new hydraulic couplings #8
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
HAY KING RENOVATOR (A52472)
HAY KING RENOVATOR...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A52748)
PENDING SELLER...
2013 Nissan Juke SUV (A50324)
2013 Nissan Juke...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
2017 Nissan Murano AWD SUV (A50324)
2017 Nissan Murano...
