Help With Driveway Drainage
/ Help With Driveway Drainage #41
On the sloped berm next to the cut I’m planning on seeding with something that’ll do well in the summer (Bahia or Bermuda…open to suggestions but it needs to tolerate sand), and then getting some erosion control rolled fabric to lay over the top while it germinates.
Inside the cut, I’ll just do some sort of stone. I don’t necessarily care if it sinks some, as the point of the cut is to be lower than the drive. There are a lot more experienced guys on here than me, so far I’ve changed my plans a few times based off the posts here.
Edit: trench is 85% done and shaped, image below
I would seed with Argentine bahia, and pearl millet, here in my part of the world. I can't tell what kinda slope you have, but if it drops more then about 3 feet over 100 ft; it might be worth having 6" high "ditch blocks" to slow water down. Erosion is driven by flow, soil weight, and Velocity. You can't really change your soil type, and the flow is kinda built in, but you can change the velocity. Only would worry about it if you see erosion before your grass gets established.
Edit; a slightly wider, flat bottom ditch erodes less then a V bottom.
Never heard of Pearl millet, gonna look into it. Thanks for the suggesting on the ditch blocks…assuming that’s just a ledge, or is that actually putting in stone? And yes, I need to take the shovel and run the bottom of the ditch flat.
Priority right now is to get the ditch 100%, then bring in some drainage rock to fill it in. Then get a load or two of crush and run to set a driveway base on the dirt side.
/ Help With Driveway Drainage #43
I wouldn't add rock or fabric until I was certain it is going to flow water as planned and doesn't require any final retouching or change in grading. If it doesn't wash, adding rock is more work and makes it harder to mow or regrade that area in the future. Can you say what grade the ditch is? It doesn't look as steep as one of our roads that hasn't washed despite being all dirt.
It looks like you essentially moved the berm from the driveway side to the other side. The ditch is now all that stands between your house and that flow of water. My thought was to have diverted the water from the road without changing the berm itself. Not knowing how much water there is, I'd want to keep my options open if I had to regrade this for some reason.
I can measure it tomorrow, but off the top of my head the angle of the actual ditch is probably 30-40 degrees.
I’m going to go take a picture, but basically I have an 18-24” wide ditch, then I have the berm off to the high side. The slope of the berm ks significantly less than the ditch.
/ Help With Driveway Drainage #45
Sorry to be confusing, but I meant the slope that the ditch runs down the hillside.
Alright see below for pictures:
Photo 1 is looking down the drive. Center you can see the small ditch, then immediately right of the ditch is what I’m calling the berm, even though it’s just a slope:
Photo 2 is looking UP the drive, from the downhill side. Ditch is to the center and berm to the left in the photo. Just a better view to show the ditch and berm.
Photo 3 shows the hastily measured angle of the berm. About 20-25 degrees.
Photo 4 shows the angle of the ditch, about 30-35 degrees.
And here’s another photo for reference:
/ Help With Driveway Drainage #47
Pearl millet is a fast growing summer grass that dies off; think of it as the summer version of rye. I did about 2 seconds of googling, and what they described is a lot taller then what they put in "summer blend contractors seed" that I'm used too.
The ditch blocks are just a 6" high, maybe 24" thick, compacted "berm" across the flow line of the ditch, slowing water down. They can also use rock or concrete, but I wouldn't start with them if not needed. I couldn't find a good picture to show. It also allows a good portion of the slowed down water to naturally perk into the soil (if your soil perks).
/ Help With Driveway Drainage #48
Kinda like a miniature dam just to cause the water to slow down and stop periodically. You can also see this on road construction where they put rock "dams" and cover with wire mesh (to hold the rocks) in the drainage ditches to keep erosion under control.
/ Help With Driveway Drainage #49
it’s going to be challenging to get grass to grow on that soil … it would be worth to Hydroseed
/ Help With Driveway Drainage #50
I apologize again for not communicating well. I meant to ask how much the grade of the ditch falls over its length from one end to the other--like from A to B.
/ Help With Driveway Drainage #51
There Jute fiber seed mat/net stuff is used on slopes and ditches on Appalachian road work. I tried to Google the product, and only found ones at TSC that didn't have seed; and planting media for Marijuana farms... we don't use it in FLa, we sod steep slopes. The product I'm talking about looks like it's made from jute baling twine, and has seed embedded in it.
On road work; we would want a 2ft strip of sod at the "shoulder" transition from the drive to the front slope of the ditch. If the drive is relatively impervious, that's gonna be one of the primary places that water will wash.
Just keep an eye on it; and if you see an erosion problem, address it, they only get bigger.
/ Help With Driveway Drainage #52
yes i thought about that too, it works .. i didn’t know how it’s called ether … it dose take longer then Hydroseed … the thing with hydroseed is it’s mix with fertilizer and it’s sticky so it’s stay in place and will grow on anything … probably way more expensive.
Ah, got it. Let me measure that this afternoon, easy.
I've looked into that option for other spots on my property. There is a company within 20 miles that I could call. I'd estimate it'd be about 1000 sqft, which according to google would be about $500-$1000 depending on local costs etc.
I am going to check with my local landscape supplier today and figure out what the have around here. Good suggestion about putting grass in the ditch. The driveway will be relatively impervious, and i expect water to shed off the drivway into the ditch.
I'd like to just get ahead of any potential erosion problems/water problems now while I have the free time to work. Based off input, i've come up with some options:
Option 1: Sod IN the ditch, grass and erosion control mat on the sloped berm, and potentially some sort of edging to separate the driveway gravel from the ditch
Option two would be to fill the ditch with rocks instead of Sod, and I wouldnt need any edging between the driveway and the ditch.
I may cut a ditch block about halfway up the slope with the tractor too.
What do you guys think of the above?
Edit: No-go on the edging, thinking about it 1 minute after posting, that would block the flow of runoff. It's early....
/ Help With Driveway Drainage #56
Before I did anything, I would start up my lawn mower and see how close to the ditch I could mow with it. Once you know where you can safely mow, then you can either remove more material, add gravel, or do something else.
/ Help With Driveway Drainage #57
I would want to make the transition more gradual on the side labeled landscape block edging so you can mow the ditch easily. If you put one side of your mower wheels into the bottom of that ditch as it is, I'd say the mower blade will scalp the ground.
/ Help With Driveway Drainage #59
A few hours spent now on making the grade mowable could avoid more hours of weed eating later.
After a couple discussions with my local landscape supplier and a Neighboor, I decided to go with surge rock for the ditch, and grass on the berm. Sod was too expensive for me, and the chance of failure was higher than I wanted for the price (I have zero experience laying sod and my soil is garbage).
I have 10 tons of surge coming tomorrow, the ditch is dug and sloped. I’ll post a picture once I get it filled with rock. Project is moving along!
6' Disc (A62613)
6' Disc (A62613)
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
2008 Chevrolet Silverado 2500 Crew Cab (A62613)
2008 Chevrolet...
2008 Big John 42' Log Trailer OFFSITE (A62613)
2008 Big John 42'...
