Kioti DK6010 3pt not going up or down.
   / Kioti DK6010 3pt not going up or down. #11
That should be your standard rear remote that comes on that tractor. Make sure the rear remote lever isn’t stuck in the detent position. Work the lever briskly to pop it out of detent and leave it in center neutral position
   / Kioti DK6010 3pt not going up or down. #12
Does Kioti use the remotes to feed the backhoe? That should be an easy fix.
Yes they do. That's where my backhoe hoses were attached
These are my three point hitch controls. The yellow knob is what I use for the PTO
   / Kioti DK6010 3pt not going up or down. #16
That was it. It wasn't in neutral. Thanks so much for all the help everyone!
Ok, that's what I was trying to understand. If they used the remotes or a loop with hoses instead. Either way, easy fix. 👍
2007 International 4300 (A53314)
2007 International...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2017 Ford F-150...
16ft. T/A Utility Trailer (A56859)
16ft. T/A Utility...
2014 Kaufman 12,000 Lb. Trailer, VIN: 5SHFD2225EB000634, Tandem Axle, Wood Deck, Tilt Deck, Asset# (A59076)
2014 Kaufman...
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
CFG Industry H12R Mini Excavator (A57149)
CFG Industry H12R...
