UTV's and ATV's general discussion.
/ UTV's and ATV's general discussion. #121
An interesting and enjoyable thread. Thanks to all who post pics.
Thanks. I just wanted to show that some folks use them for work and might give them idea's how they could.
/ UTV's and ATV's general discussion. #123
Do you know what the power draw is?
Most of the bigger Northstar I believe use a 5.5gpm NSQ pump that's rated at 17 amps at 12 volts.
I have one and use the 5.5 gpm boom-less northstar sprayer with my JD Gator. I installed an SAE connector directly to the battery to make attaching and disconnecting easier. I also use a 60Gallon tank with a HF transfer pump to allow me to spray longer before refills. I put a 'T' on the SAE connector so I can attach both at the same time. The battery/alternator on the JD doesn't have any issues keeping up.
17 amps is lots!
/ UTV's and ATV's general discussion. #126
This was an hour before the motor literally exploded... There are 4 holes in the crank case. Low hour Briggs. 😂. Now I can use the new tractor to lift the old motor off.
/ UTV's and ATV's general discussion. #129
17 amps is lots!
That's why I bought 10 gauge connectors. The Gator's alternator is either 40 or 55 amps so everything keeps up.
You can definitely tell a difference spraying if you have the motor off vs on. All in all the setup works great.
/ UTV's and ATV's general discussion. #133
Finally got sick of looking at this broken pull behind mower so I finally repaired it and it's going up to cabin to mow my dangerous sloped hillside with a 4wheeler instead of using my old 212. Rigorous testing was involved down state first, safety guards reinstalled and it passed my lacky standards lol.
/ UTV's and ATV's general discussion. #135
Spent the day yesterday doing yard work.
Brother in law says I'm cheating and I should be using a shovel....told him I was
/ UTV's and ATV's general discussion. #138
Nothing special. Just a 2wd Rancher.
/ UTV's and ATV's general discussion. #139
Dump trailer full:
Unlatched and dumping:
Backed up more. Max dump:
Pulling forward:
Empty and latched:
/ UTV's and ATV's general discussion. #140
Getting 2 acres sprayed today, 40 gallons total. 40psi and 4mph. 12' spray width. Just clearing out some weeds from the new barn build lawn and some in the house yard. This sprayer is one of my top 5 best investments.
